How to Make Red and Clear Glass Beaded Collar Necklaces
1,278
36
Published
Introduction: How to Make Red and Clear Glass Beaded Collar Necklaces
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
This Pandahall tutorial will show you how to make a red and clear glass beaded collar necklace step by step. Hope you like this red and clear glass beaded necklace.
Step 1: Supplies Needed in DIY the Red and Clear Glass Beaded Necklace:
6mm Red Bicone Glass Beads
6mm Clear Bicone Glass Beads
2mm White Round Seed Beads
Silver Jump Rings
Spring Ring Necklace End Clasps
0.2mm White Fishing Wire
Stainless-Steel Scissor
Step 2: Make the First Part of the Red and Clear Glass Beaded Necklace
1st, cut about 300cm 0.2mm white fishing wire. Then, thread a spring ring necklace end clasp to the middle of the wire. Add 5 2mm white round seed beads to the left wire and 4 2mm white round seed beads to the right wire (as shown in the picture);
2nd, make some knots with the two wires and cut off the upper wire (as shown in the picture);
3rd, add a 2mm white round seed bead and a 6mm clear bicone glass bead. Repeat this step twice (as shown in the picture);
4th, cross the wire through the clear glass beads and seed beads (as shown in the picture);
5th, add 2 2mm white round seed beads and a 6mm clear bicone glass bead. Repeat this step once. Then, add a 2mm white round seed bead (as shown in the picture);
6th, cross the wire through the second seed bead (count from bottom to top). Then, add a 2mm white round seed bead and a 6mm clear bicone glass bead (as shown in the picture).
Step 3: Make the Second Part of the Red and Clear Glass Beaded Necklace
1st, add 3 white seed beads, a 6mm clear bicone glass bead and 2 white seed beads in sequence (as shown in the picture);
2nd, cross the wire through the seed bead. Then, add a white seed bead, a 6mm clear bicone glass bead, 3 white seed beads, a 6mm red bicone glass bead and a white seed bead in sequence(as shown in the picture);
3rd, cross the wire through the second seed bead (as shown in the picture);
4th, add a white seed bead, a red glass bead, 2 white seed beads, a red glass bead and a white seed bead in sequence (as shown in the picture);
5th, cross the wire through the second seed bead (count from bottom to top). Then, add a white seed bead, a red glass bead, 3 white seed beads, a red glass bead and a white seed bead in sequence (as shown in the picture);
6th, cross the wire through the second seed bead (as shown in the picture).
Step 4: Make the Rest Part of the Red and Clear Glass Beaded Necklace
1st, refer to the 2nd step to the 3rd step in Step 2 to make another bead pattern (as shown in the picture);
2nd, refer to the 4th step to the 6th step in Step 2 to make another red glass bead pattern (as shown in the picture);
3rd, refer to the above steps to make more such bead patterns (as shown in the picture);
Step 5:
4th, add a silver jump ring to the other end (as shown in the picture).
Step 6:
5th, connect the two ends of the red and clear glass beaded necklace together.
Here is the final look of the red and clear glass beaded necklace.
Do you like this red and clear glass beaded necklace? Once you gasp how to make the first basic bead pattern, you may find it's not that difficult to make the whole necklace by yourself. Have a try if you're interested in this red and clear glass beaded necklace.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    2 Comments
    Hello, thanks. And you can also have a try~
