How to Make Rf Remote Control Home Automation System Diy
Published
Introduction: How to Make Rf Remote Control Home Automation System Diy
About: I like to make diy electronics,electrical and life hacks projects.
Hello everyone,
I will show you how you can make a simple 4 channel rf remote control home automation system for your home.
You can control your any home appliances by using this device...You can control like led bulb,fan,mobile charger,fridge etc....
In this project we will use a 433 mhz rf module...The maximum range you can get upto 50 meters.
So let's start...
You can subscribe my YouTube channel-https://www.youtube.com/channel/UC8Af_aeyqsQijTBXTguaG3Q
Step 1: Watch the Video
Step 2: Buy the Components
1.4434Mhz rf module
2.HT12E & HT12D IC
3.18PIN IC BASE*2
4.5V SUPPLY
5.10K RESISTOR*4
6.51K RESISTOR*1
7.1MEGA OHM RESISTOR*1
8.PUSH SWITCH*5
9.LED *2 10.1 K RESISTOR *6
11.CONNECTING WIRES 12.5V,1C/O RELAY *4
13.1N4007 DIODE*4
14.BC 548 or bc 547 TRANSISTOR*4
15.PCB BOARD *2
16.ANY MOBILE BATTERY OR 2*1.5V BATTERY
17.CHARGING SOCKET FOR MOBILE PHONE BATTERY IF YOU USE MOBILE BATTERY
18.miscellaneous items(SOLDERING IRON,WIRE CUTTER ETC)
Step 3: Circuit Diagram
Step 4: Assemble the Circuit
You are ready to go
Subscribe my YouTube channel-https://www.youtube.com/channel/UC8Af_aeyqsQijTBXTguaG3Q
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
