3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Rice
How to Make Rice
Cooking rice is a valuable skill that you'll use many times over a lifetime of eating. This Instructable will show you how to cook both white and brown rice. It's not a strict "recipe" like existing web pages out there. It's the theory behind cooking rice, so that you can become your own expert at cooking rice.
Step 1Rice theory
Rice theory
Cooking rice is about understanding the proportions of the two ingredients, the rice and the water. Some people prefer using different ratios of rice to water. The range goes from 1 part rice to 1.5 parts water to as much as 1 part rice to 2 parts water.
After you cook it a few times you'll have your own ideas about how much water to use, for now, we'll walk the middle of the road and use 1 part rice to 1.75 parts water.
If you've added in too much water, fear not, simply cook your rice longer and crack the top allowing more moisture to escape. If you've added too little water, you're in luck, because you can always add more!
Ideally you won't need to make the adjustments described above when you're cooking rice, and your batches will come out perfectly fluffy, moist, with just the right amount of chewiness and only enough starchy glueyness to keep the grains clumped together enough to get them into your mouth.
White Rice vs. Brown Rice
Cooking methods vary slightly for white and brown rice. White rice is generally speaking, cooked for a shorter period of time (20-30 minutes), with less water. Brown rice is cooked for a longer period of time (30-40 minutes), with more water.
Rinsing the rice
Some methods suggest rinsing rice before combining it with water in the pot. This is an attempt to "wash off" the excess starches on the outside of the rice which purportedly make the rice gluey. I haven't noticed any real difference in final results between doing this and just going straight to the pot. The real quality comes from the cooking method in my opinion.
Toasting the rice
Other methods call for the rice to be cooked in the pot for a few minutes before the water is added in. This is a useful technique when trying to impart additional flavors to the rice. When making a middle eastern style basmati rice, or an Italian arborio rice used in rissoto, I would fully suggest this process, however, for just making plain, unflavored white or brown rice as we are in this Instructable, this step is unnecessary.
I just find it important to always state that when cooking, there's no need to follow the recipe exactly. If you can understand what's going on inside the pot, then there's often many ways to cook something delicious and successfully. Take the recipe as a grain of rice.
39 comments
Nov 2, 2008. 4:53 AMAleksandr Skotbot says:
I don't mean to disagree, but I just thought I'd add that I was taught by my mother to boil the water alone and then add the rice. It's never failed me, and I would imagine it's at least a couple minutes faster. However, I never figured out how to reheat rice without the use of a microwave. Any thoughts on that one? It hasn't been a problem in the past with white rice, but when I make the switch to brown I'll be a little more concerned.
Jun 8, 2011. 11:42 AMsuayres says:
Put the ( already cooked) rice in a steamer and steam over boiling water for a few minutes. Hey, presto! Hot rice.
Mar 5, 2009. 5:37 PMinkstainedheart says:
When reheating, I've always added a little bit of water or milk to the rice. That way the rice doesn't end up all crunchy and gross.
Oct 15, 2010. 7:37 AMBH-Inspector says:
IKEA-Clock :D
Feb 19, 2010. 12:00 PMBlue Leopard says:
In my experience, a few drops of cooking oil will help keep the starchy water from bubbling over the edge of the pot. I also tend to add at least half a teaspoon of salt per cup of rice to the pot after putting it on to cook.
Sep 25, 2008. 6:06 PMwestfw says:
A couple more comments:
  • Rinsing of rice originates in older and further places than the US. It helps remove the bugs and rocks and things that can be found in bulk rice that hasn't been processed to the pristine standards of the US consumer. Also, US rice is supposedly frequently "enriched" by adding some vitamins and such, and apparently you can rinse them away (accidentally or on purpose?) (I have also never noticed a difference in texture/etc caused by rinsing or the lack thereof.)
  • A lot of the "fear" in cooking rice seems to be due to some idea propagated by a marketing department somewhere that rice isn't supposed to stick together. This is pretty much nonsense, and I think that it's been going away as americans have been exposed to more ethnic foods. (At least, the desire for non-sticky rice has gone away; the fear of cooking rice remains :-) If you want non-sticky rice ("french style"?), start with "converted rice" (like Uncle Bens) and follow their directions. (UB is probably responsible for the whole thing. "Our rice doesn't stick together." "SELL the fact that it doesn't stick together!")
  • Instant rices tend to be pretty awful. If your opinion of rice is based on Minute Rice or the equivalent, you really do want to try something else. The 30 minutes or so that it takes to cook rice "the long way" is mostly unattended simmering, so you can do something else then anyway.
  • Rice is pretty popular. A couple winters ago, I wanted some "snack" to deliver backstage to the middle school drama group during their play, since the timing of putting on a performance pretty much interferes with dinner. I wanted something warm, not too messy, not likely to develop food poisoning, relatively nutritious, not known to interfere with voices, hypo-allergenic, not too expensive, and not difficult to cook (being a busy guy.) So I threw some rice into the rice cooker and sent that. I knew my daughter would eat some, and probably a few others, but if no one liked it, there was no big loss, either... It was EXTREMELY well received; much more so than I expected! I took more the next night, and it now seems to have become a tradition. "Hi Mr WestfW. Did you bring rice?" I can live with that.
Nov 2, 2008. 4:50 AMAleksandr Skotbot says:
if you want rice that is not sticky, add some oil at the beginning. (:
Jan 13, 2010. 9:02 PMmastermaker says:
or fry the rice with butter before adding the water(let the rice cool down a bit though, or else the water can flash-steam and burn your hand, i would know, lol)
Sep 25, 2008. 12:58 PMHarvey_ says:
Your title is incorrect. You don't make rice, you cook it. Rice is grain that isn't made, its grown. :)
Sep 25, 2008. 2:18 PMSpiff73 says:
And, you cannot make an apple pie from scratch until you learn how to create apples.
Nov 5, 2009. 12:25 PMdavebrown says:
If you wish to make an apple pie from scratch, you must first invent the universe.
Jun 29, 2009. 6:01 PMAzayles says:
Or grow them :-P
Sep 25, 2008. 6:08 PMHarvey_ says:
Yes, blame others for the misuse of words. :) In any case, great write up. I already knew how to "cook" rice, but its assuring to know that I've been doing it the correct way.
Sep 25, 2008. 1:55 PMstandupclothing says:
i was thinking the same thing about the title.... nicely put together though, and made me hungry for rice!
Sep 19, 2009. 5:58 PMNatureBoom21 says:
Ughh. I HATE rice. It tastes disgusting!!! Well not really. I just hate it.
Aug 25, 2009. 2:20 AMRhsameera says:
I'm from sri lanka.our main food is rice. but we make it as seperate
Jun 25, 2009. 1:01 PMnoexit says:
Your water amounts are not that clear. You say 1 3/4 water to 1 cup rice, but don't say what kind, or if it's washed rice or not. When I make Japanese rice, I wash it, and once drained, add only 1 1/8 cup water to every cup rice. This is based on my rice cooking training while in Japan.
Sep 25, 2008. 1:08 PMkillbulletbill says:
I like to substitute coconut milk for the water. Try it and it will blow your mind!
Mar 5, 2009. 5:39 PMinkstainedheart says:
That would be awesome for rice pudding!
Apr 17, 2009. 7:41 AMnightninja87 says:
its actually good if u add some fresh cold mango after u cook the rice and let it cool till its still warm very nice taste i love it
Oct 15, 2008. 1:23 PMlinuxmom says:
And then there is "red rice"---use tomato puree instead of the water. (Toss fresh tomatoes from the garden or market in the blender and puree away.....) . And If you don't have enough puree , add water. Great with fresh basil.....Mmmmmm
Sep 25, 2008. 1:37 PMjongscx says:
Personally, I It's a pretty big waste to actually cook the rice WITH the coconut milk, as a bit of the flavor is lost during the cooking process (proteins get denatured by heat, as well as oils separating) and you end up needing a lot of coconut milk to make up the 2-to-1 volume needed. I suggest cooking the rice as usual with water, and around step 4, when the rice is "mostly cooked", adding the coconut milk.
Sep 26, 2008. 6:21 PMPh3nomin0n says:
Thats what I do except I cook the rice regular then drain as much water possible and in a large Wok stir fry it in the coconut milk making it brown and crispy... In my family we have to make 6 cups of coconut rice because each person has atleast 3 servings... And with steak or ground chuck it makes one heck of a dish
Apr 15, 2009. 6:04 PMqueen717 says:
all sound delish :) try adding a lil ground corned beef,tomato puree,and a puerto rican fav sazon! all cooked together of course then add it to the rice :D a personal fav! plus to give it even more flavor you could add some diced onions or green bell peppers or both :D it's just amazzzzzingg! it's kinda like puttin corned beef hash w/ rice.
Dec 25, 2008. 7:21 AMdollarside says:
nice, everyone (should) love(s) rice!!!
Oct 23, 2008. 6:39 AMAlcreion says:
Where my family originates (Laos). We cook rice a lot differently. We let the rice soak in water for most of the day so its nice and juicy, then we kind of steam it with type of pot and a thin wooden thing to put the rice in. Thats how we make sticky rice though.
Dec 23, 2008. 6:51 PMrattyrain says:
Do the grains become enlarged?
Dec 24, 2008. 10:04 PMAlcreion says:
yup it like soaks all the water, but you have to wait like all day. so you like soak it when you wake up come home from school, work, w.e and then cook it
Dec 23, 2008. 7:09 PMfwjs28 says:
yummm..... i can hear the chinese resturaunt music already.......
Oct 20, 2008. 8:32 AMcompacho says:
Wow. Even though I know how to cook rice now, I must say this is probably one of the best and most complete Rice how-to's out there. Great job! I will definately refer other people to this page if they ever need help. Another simple way to enhance the flavor is by substituting half the liquid for chicken stock. Or, u could keep the same amount of liquid and add a bouillon cube. I come a spanish family so I've eaten my fair share of flavored rice, but no matter how much of I love it, I still prefer plain, lightly salted, white rice. :)
Sep 28, 2008. 1:40 PMkrowii says:
Great 'ible! I remember the good old days when I had to cook rice in a pot...that was before I got my Zojirushi fuzzy rice cooker.
Sep 26, 2008. 10:34 PMFreshPineSent says:
How to *cook* rice.
Sep 26, 2008. 7:22 AMinquisitive says:
Ah, the food of my people...lol. Nice iBle, my mom would be proud-except for the rinsing part-that is mandatory in my home (two times rinse in cold water and the third time is the water that stays in the pan). We don't measure the water though we just touch the rice with the tip of our finger and have the water come up to approximately the first knuckle. By the way, different harvests of rice can differ in amounts of water needed-so if the exact amounts and timing come out different-just go with the flow and adjust. Don't give up-I guarantee you will burn a couple batches-Mom never let me forget those-enjoy.
Sep 25, 2008. 9:40 PMDrSimons says:
Nice! Never knew how rice is actually cooked. We always just use a rice cooker in my family...but now, when I move out that's one less thing I'll need to buy. Sticky rice is way better!
Sep 25, 2008. 2:47 PMjessyratfink says:
This is a really good beginner's guide, sir! I think I could live off rice. Especially jasmine. We always have at least 10 lbs of it on hand. :D
Sep 25, 2008. 1:57 PM=SMART= says:
Very Good !! I like sticky rice the best !
Sep 25, 2008. 1:55 PMwestfw says:
It's worthwhile to have a "rice tasting"; find one of those upscale markets that has a wide variety of rices and buy half-a-dozen or so. Cook them up, either similarly or per package directions, and taste them side-by-side (it's a good thing that rice reheats pretty well!) The differences between "Uncle Bens" and a brown Basmati rice are pretty dramatic. (alas, in our family the kids prefer white sushi rice (jasmine a close second) and the adults prefer brown basmati rice.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
891
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
