Remove these ads by
Signing UpStep 1: Buy them
For the retro, 1930's strongman look, choose the kind with round, bulbous ends. These are found pretty cheap at discount stores like Ross, TJ Maxx, and Marshalls.
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Try wax!
While the weights are still quite warm(but not so hot they burn you),
take some nice high-melting temperature wax, and rub it all over the iron.
Once cool, wipe off any wax that hasn't soaked in with a dry cloth.
Nice iron color. rust prevention. no coating to wear off.
The castings can be pretty darn rough, under that rubber(the non-coated ones are better castings, and receive better finishing). Consider hitting the handle area with a wire-wheel. either on a dremel, an angle grinder, or a bench grinder style mount.
this will improve your desire to continue to use the weights by 20-30%. If you leave it as a rough raw casting, within days, your hands will be so chewed up, you'll want to throw the weights straight into the recycle bin.
Can you suggest a brand or specific type of wax for this?
um... not birthday candles?
Usually, for iron and steel sculpture, I actually use Peanut oil... but you need higher tempatures for that(120F, 130F) but gives a nice brown color.
I'd say, use anything you have on hand, other than soy or bee's wax.
Even the wax off of wax-paper would work :-)
Birthday candles would be paraffin wax. Thanks!
Paraffin wax wouldn't an ideal choice for me, as the fume-y smell does make me a little ill. It's a petroleum derivative and probably not the best for your health.
I guess I'll stick with the spray paint and polyurethane. Once dry, they don't come off in the air or on your skin.
