Introduction: How to Make Sansa’s Necklace From Game of Thrones
How to make the necklace Sansa wears in season 6 and 7 of game of thrones
Step 1: Get Your Supplies
For this necklace you will need:
- Crayola Model magic (any colour)
- A foam brush
- Black acrylic paint
- Some thin wire (optional)
- Crazy glue (optional)
- Mod podge
- Chain
Step 2: Make the Base
Roll out two pieces of model magic. One should be longer and thicker the other thinner and shorter. This will create the main part of the necklace.
Step 3: Create the Base Continued
Attach the ends on the bigger piece together to make a circle. Then get the smaller piece and attach the two ends on either side of the circle. this will make a bar going through the centre of the circle creating the look of Sansa’s necklace. Allow to dry.
Step 4: Paint the Base
Use your sponge brush and black acrylic paint to paint the base you created. Allow paint to dry.
Step 5: Add Support (optional)
To increase the strength of the middle bar gently push some thin wire through it. Secure it with crazy glue.
Step 6: Finish the Necklace!
Touch up the black paint if you need to then add a few layers of Mod Podge. Allow to dry between coats. Once fully dry add some chain and you’re done!
Halloween Contest 2017
