How to Make Simple & Easy Amplifier Using LM386 With High Gain
2,985
60
Published
Introduction: How to Make Simple & Easy Amplifier Using LM386 With High Gain
About: I like making new things from trash. For more cool content please subscribe to my YouTube channel @ https://goo.gl/BHxFf7
In this tutorial i will show you how to make a Simple & Easy Amplifier Using LM386 With High Gain. And i also included two alternate circuits with this post.
The Video Tutorial is also embedded along with this tutorial.
Step 1: Parts List
Parts List
1. LM386
2. Resistor
3. Capacitor
4. IC Base
5. Terminal Blocks
6. PCB
Purchase List or Affiliate Links
Ali Express
1. LM386 - https://goo.gl/hfw9Iw
2. IC Base - https://goo.gl/AUPRRx
3. Complete Amplifier - https://goo.gl/CxfPsD
Amazon Ind
1. LM386 - http://amzn.to/2t1CKFF
2. IC Base - http://amzn.to/2rqTcCc
3. Complete Amplifier - http://amzn.to/2rvuf3N
Amazon USA
1. LM386 - http://amzn.to/2ss5pXe
2. IC Base - http://amzn.to/2ssfLXa
3. Complete Amplifier - http://amzn.to/2rh0NiC
Step 2: Circuit Diagram
Using the circuit diagram given in this construct your PCB board.
Amplifier Features :
1. Very little parts are required
2. Works with 5 to 12V range.
Note : At 5 volt the amplifier gives out some noise which can be reduced using a Pot. The circuit diagram for the same is given in the next step. For design or circuit diagram which is shown in this step the optimal operating voltage is above 9 volt & below 12 Volt. Above 12 Volt the IC LM386 starts getting heating.
3. Gain is between 20 to 200
Testing :
In the video i have tested the circuit under three conditions
1. Testing with 5 Volt - with 5 volt the output ha some noise in it
2. Testing with 12 Volt - With 12 volt the output is noise free
3. Testing with Volume control
For test results of this amplifier you can watch the video attached with this tutorial or Click Here
Testing begins @4:20
Step 3: Alternate Circuit Diagrams
I have added two extra circuit diagrams.
1st Image - In this circuit there is only one change from the initial circuit diagram. i.e i have added 10uF/16v capacitor to the pin 1 & 8 of LM386
2nd Image - Pin outs of the 1st image in this step
3rd image - In this circuit there is only one change from the initial circuit diagram. i.e i have added 10k pot for the volume control
Thank You for Reading.
For more such projects you can visit my YouTube Channel by CLICKING HERE
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    3 Discussions
    what will be the power output, and what speaker could be used.
    You can easily connect two 3 watt 8 Ohm speaker.
    I have added two circuits.
    1. Circuit shown in the step 2 has a gain of 20
    2. Circuit sown in the step 3 has a gain of 200
    For results you can watch the video attached along with tutorial.
    Please Don't Forget To Vote For The Contest. Please click the Vote Button on Your Right Hand Top Corner to Vote
