How to Make Slime
26
Posted in CraftArt
Introduction: How to Make Slime
This is how to make fluffy slime!
Step 1: Ingredients
1/2 cup (4 ounces) school glue
1/2 cup (4 ounces) shaving cream
Slightly more than 1 tbsp. cornstarch
Borax (1 teaspoon)
1 cup hot water
Lotion (optional) Food coloring (optional)
Step 2:
Start off by making the borax solution. Take 1 teaspoon (4.9 ml) of borax powder and add it into 1 cup (240 ml) of hot water. Mix it until it's thoroughly dissolved and set aside for later use.
Step 3:
Pour ½ cup (120 ml) of glue into a separate bowl. Add ½ cup (120 ml) of shaving cream into the same bowl as the glue.
Step 4:
Mix until there are no lumps. Add in about 1 tablespoon (15 ml) of cornstarch. The cornstarch helps to thicken the slime and allows it to retain its shape.
Step 5:
Add in food coloring if you want. Go for 2 drops at a time. Mix.
Step 6:
Add 3 teaspoons of the borax mixture to your slime. Stir thoroughly, then continue adding the borax mixture 1-3 teaspoons at a time until the slime is at the consistency you’d like it to be. You will probably not use all of your borax mixture.
Step 7:
Take your slime out of the bowl and knead it on a cutting board or some other hard surface. If the slime is still too sticky, add about 1 teaspoon of the borax mixture and carefully knead it in. If your slime is fluffy, but not very stretchy, add a few pumps of lotion into your slime, rub it into the slime, and then knead it again.
Step 8:
All done! Here's a little fun fact: Slime was first introduced by toy maker Mattel in the winter of 1976.
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
