3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Sodium Metal [HD Video Tutorial]
video How to Make Sodium Metal [HD Video Tutorial]
First some safety: The experiment described uses corrosive chemicals and mixtures capable of burning without presence of atmosphere. It should be done outdoors in cotton clothing as fire protection, with chemically resistant gloves, and of course lab goggles. In case of fire, wait for initial reaction to subside, then use a class D extinguisher - do not attempt to put out fires with sand or water.
A recent experiment of mine involved the production of the highly reactive element sodium from sodium hydroxide and another less reactive metal, in this case magnesium. The reaction is as follows:
2Mg + 2NaOH = 2MgO + 2Na + H2
The magnesium (finely powdered) first ignites burning in atmospheric oxygen contained in the reaction vessel. This initial reaction produces enough energy to initiate the primary reaction. The Mg has enough desire for the oxygen contained in the NaOH to actually rip it from the hydroxide group, freeing hydrogen gas and sodium. The reaction is violently exothermic. More than enough energy is released to ignite the hydrogen gas which burns as the reaction progresses. The sodium is produced in a liquid state due to the temperature of reaction, and some of it vaporizes giving the flame a strong orange/yellow color.
To keep the sodium from burning immediately upon production, a loose fitting lid is placed over the reaction vessel, allowing the burning hydrogen to escape, but sealing the vessel off from atmosphere once completed. The lid is then not removed until the reaction cools to air temperature, at which point mineral oil should be added to the resulting slag to prevent further oxidation of the product.
Presumably this experiment could be preformed with other metals acting upon the hydroxide group, such as aluminum - in fact, I've heard aluminum gives a better yield because of a lower reaction rate and temperature which vaporizes much of the Na using Mg. I have not yet tried it. It is also quite likely that this process could free most if not all metals from their hydroxides because the reaction does not involve the metal contained in the hydroxide, but the hydroxide group alone. All hydroxides should therefore be susceptible to separation via magnesium and possibly aluminum. I will conduct further experimentation in warmer weather.
22 comments
Apr 23, 2012. 9:51 AMsolomonhorses says:
totally amazing!!!
Nov 28, 2011. 9:43 AMtaliran says:
aaaaaamazing...
Nov 26, 2011. 7:51 PMZappingLover1337 says:
this is amazing please check out my instructables please thanks!!!!!!
Nov 10, 2011. 4:43 PMleopard10 says:
I probably couldn't do that but it is so COOL1
Sep 22, 2011. 4:13 PMcowscankill says:
Still one of my favorite chemistry videos. I've been wanting to try this for a while now.
Oct 2, 2011. 10:43 PMGaark says:
I watch other people do these things so I don't have to ... :D
Sep 30, 2011. 2:09 PMRhamkota says:
Do you mean wool? not cotton.
Oct 2, 2011. 3:49 PMdidgitalpunk says:
true i am in sientific setion in high school and they told us that cotton is basily one of the ONLY thing that is good for all types of experiments.
love the video by the way!
Sep 30, 2011. 2:06 PMcrjeea says:
Still think carefully removing the Lithium from Lithium batteries is quicker.
you must loose quite a bit of Sodium along the way in this reaction and it doesn't appear to be that pure at the end but still not much effort and a fairly fiery reaction so looks good enough. may well give it a go next time I get hold of some Magnesium.
Sep 30, 2011. 10:44 AMMinifig666 says:
Awesome!
I guess the same wouldn't work using potassium hydroxide?
Would a proper fuse be necessary or could I just use some newspaper?
Also how dangerous do you think it would be to melt it under mineral oil to turn it into a proper ingot?
Thanks!
-Minifig666
Sep 30, 2011. 12:10 PMMinifig666 says:
Ok thanks, I feel a big purple flame coming along shortly!
If I ever get a vacuum pump that works I could have a go melting it 'in vacuo' or perhaps under argon! For now I'll have to dig out my extinguisher and give it a go, it shouldn't take too long to bring potassium up to 63oC with a torch... :)
I'll get back to you on how well the melting goes...
-Minifig666
Sep 28, 2011. 1:28 PMcorradini says:
This is interesting but pretty incomplete. You casually mention "prepare graphite or carbon electrodes for electrolysis" as if that requires no add'l explanation for someone who's LOOKING for instruction, here - for something that makes chlorine gas and caustic lye(!) >;-) There's no discussion of the electrolysis -- it matters whether it's AC or DC, and what the voltage is.
Maybe I can help a wee bit: You're using, I believe, a Radio Shack (or similar, like the Coby CA-11 I've got sitting here) multi-voltage AC-> DC converter, so I'm guessing about 300mA max (esp. given that it took "a few hours"). No clues on the voltage switch position you've got it on, but you probably maxed it at 12, 'cuz why not? I'm also taking a WILD guess that your electrodes are pencil leads, hopefully from a #1 pencil (less clay/more graphite), which would probably be easiest to extract by the simple expedient of setting a pencil on fire.
My other (polite) gripe is that the comments under the video are essentially irrelevant - they're for (and from) another video of yours about the next step.
Finally: there're plenty of "don't try this at home or you will certainly die a horrible death" vids on Instructables (never mind YouTube ;-). This is one of them, and I think you need to be a little more forceful about that, particularly given that your instructions are pretty vague.
Let's review: we're igniting magnesium, which burns at 5,600F -- mixed with caustic lye which has roughly the same skin/eye-burning mojo as sulfuric acid. THEN we're pouring a flammable liquid into this mix which recently was burning at a few thousand degrees -- only now it contains elemental sodium, which we're tossing in water (in which it violently combusts and/or explodes), and said flammable liquid. OH - did I forget that we start out by generating chlorine gas, as in: a chemical warfare weapon banned since WWI? I probably left a few other blinding/maiming/choking/dying possibilities out, but that should do for the appetizer. (Oh, yeah - electrocution, if they use dad's battery charger or jumper cables or just strip zip wire and drop it in, which is absolutely a possibility given some of the idiot comments on some similar vids....)
Look: I love the overall process, and your intent - I don't mean to (pun intended) flame you. I just suggest, as a rather seriously experienced amateur chemist (and I do some very high-temp metalcasting as well) who still has all his fingers and binocular vision, that you add both some detail and some additional warning 'oomph'. 14-year-old trogloteens who can't spell the word "I" read this kind of stuff, and some will promptly run out and try it. Liability aside - you really probably don't want some dope kid to end up blinded and/or in the burn ward, or even burning his mom's trailer down...
Warnings Are Good. Detail is too. Best regards!
Sep 30, 2011. 1:33 PMBen Mighall says:
(removed by author or community request)
Sep 30, 2011. 2:34 PMcorradini says:
Hey Ben,
Sorry - not sure whether you mean me or the OP (NightHawkInLight) is "dumb" and "doesn't know crud". Either way, though? Rude. Not nice. Not helpful. And untrue.
I goofed - my response was to both this post AND to his related post. (Seems he missed that, but that's another issue.)
However: he's obviously pretty smart, and does know rather a lot of stuff about chemistry, and this topic. I've got some quibbles, but they're pretty much about safety, not intelligence or accuracy. And - sorry - I own 2 chemical/energy companies, have 2 patents in the area of catalysis and reactor design filed and more coming, in conjunction with several PhDs in chemistry and chemical engineering.
So - whoever you're insulting -- me or the author -- bad move. Plus, it's against the site policy, and I've flagged your comment as such. Look - if you can't be nice, at least be CONSTRUCTIVE and rude... ;-)
Sep 30, 2011. 3:10 PMBen Mighall says:
You remind me of my friend Nick. lol he's got your sense of humor. I just deleted it so no hard feelings right? (And it was directed at the author)
BTW which companies?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
366
Author:NightHawkInLight
Hundreds more videos can be found on my YouTube page: http://www.youtube.com/user/NightHawkInLight
