3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Sodium Nitrate, A Potassium Nitrate Substitute
video How to Make Sodium Nitrate, A Potassium Nitrate Substitute
How to make sodium nitrate, which can substitute for potassium nitrate for most purposes.
Note: Sodium Nitrate is somewhat hygroscopic. Stuff you make from it such as pyrotechnic compositions should be used soon after making and not stored for extended periods of time.
WARNING: Both procedures produce large quantities of ammonia gas. You have to do this experiment outside or in a fumehood.
First get ammonium nitrate from an instant cold pack as seen in our previous video: http://www.youtube.com/watch?v=6iMeBxNcZf0
For the baking soda method. Get 80 grams of ammonium nitrate and dissolve it in 150mL of water. Filter it off directly into 84 grams of sodium bicarbonate, which is baking soda. Then boil the mixture down to 100mL or less. This is needed to decompose the ammonium bicarbonate that's formed. It cannot be skipped. The boiling will release large amounts of ammonia so you have to do this outside or in a fumehood. Once it's boiled, leave it to evaporate until dry.
For the sodium hydroxide method: Place 80 grams of ammonium nitrate in a tall container and pour 40 grams of sodium hydroxide on top. Then carefully pour 30mL of water and stand back. It will quickly react to generate ammonia gas and sodium nitrate. Stir the mixture to make sure it's completely reacted and then add another 50mL of water and stir until dissolved. Filter it out and let the clear solution evaporate.
Both methods will produce pure sodium nitrate.
To test the sodium nitrate for reactivity just mix it with an equal amount of sugar and set it on fire. Sugar does not burn by itself but with sodium nitrate it will burn with a bright yellow flame.
Sodium hydroxide is also known as Lye, Caustic Soda, or "Red Devil Lye" and can easily be purchased online.
45 comments
1-40 of 45next »
Aug 1, 2011. 6:37 PMXOIIO says:
you can safely makeit inside using amonium nitrate (from cold packs) and potassium chloride (salt substitute)
May 4, 2012. 8:30 AMelectronicz says:
That makes Potassium Nitrate, not Sodium Nitrate. I have tried it.
Jan 25, 2012. 4:34 PMTaylorLA says:
when i make sodium nitrate how i store it ?
Jul 15, 2011. 3:23 PMcucolea says:
very nice tutorial . I have some questions:
How can i test if my ammonium nitrate fertiliser its good enough to make sodium nitrate and potassium nitrate?(it was delivered with no info and in a normal bag without no brand name)
and
How can i purify my ammonium nitrate fertiliser without using methanol(rare and expensive in my country)?
Oct 12, 2010. 2:38 PMPyro the maniac says:
For the baking soda method, is proportion important? Due to the fact im using used coldpack water i cannot really measure 80 grams of ammonium nitrate due to the fact its already disolved. Any suggestions?
Thanks!
Apr 26, 2009. 2:08 PMjfrazierskybeam says:
the Ice packs that I have say that they are sodium nitrate already is there a prosses to make this purer or more potent? cause it is not flammable with surger as in the video I'd appreciate the help!
Jun 5, 2010. 5:23 PMtylervitale says:
Yeah actually, typically in any pyrotechnic composition, purity tends to be fairly important.
Jul 19, 2009. 7:56 AM___ says:
could i boil it all the way till dry?
Jun 5, 2010. 5:20 PMtylervitale says:
I really wouldn't recommend it. If you heat it enough, it decomposes into nitrogen dioxide and sodium oxide in a decomposition reaction as follows: NaNO3 -> Na2O + NO2.
May 31, 2010. 8:24 AMJoona-96- says:
i tried sodium nitrate/icing sugar mix in small model rocket engine tube, and it didn't work really well, i think NaNO3 doesn't burn fast enough to work in rockets or r candy. but you can try that yourself ofcourse. But if you add some aluminium powder to NaNO3/sugar mixture it will burn faster. i tried that and it burned a lot faster, and brighter.
Jun 5, 2010. 5:16 PMtylervitale says:
Bare in mind, that the chemistry for black powder and rocket candy using sodium nitrate as a substitute for potassium nitrate, is a little different. for example black powder is 75:15:10 KNO3 to Charcoal to Sulfur. but using sodium nitrate the ratio amount of NaNO3 is lowered to only 69 parts by mass. The charcoal and sulfur measurments are slightly tweaked too, so google it.
Aug 15, 2009. 4:27 PMjunits15 says:
will this method work to make r candy?
May 12, 2010. 8:52 AMkrazy9987 says:
i would like to know the answer to this as well
Mar 11, 2010. 10:37 PMJoona-96- says:
I made this stuff yesterday like half a kilogram, and it worked really well! thx for instuctable!
Jun 15, 2009. 10:15 AMcowscankill says:
Sweet. I might subscribe. Chemistry pwns
Mar 7, 2010. 10:59 AMThundertydus says:
Time travelling stalkers, great!
Mar 7, 2010. 4:03 PMcowscankill says:
Wtf...?
Feb 18, 2010. 3:09 PMcharlie c says:
 what can this b used for? can it be packed together to make a small charge or something?
Jan 30, 2010. 9:19 AMantidartan says:
at the moment I have a white substance at the bottom of the jar and a liquid over top of it. Its only been a day for evaporation but there are no crystals yet. When I boiled the solution I could smell the ammonia, so I assume things were going OK. does this sound like I'm on the right track?
Oct 21, 2009. 8:10 AMmr.space says:
 If you did this with potassium chloride, would you get ammonia chloride and potassium nitrate?
Jul 3, 2009. 4:22 PMobs1234 says:
I have pure white Ammonium nitrate. Would I still have to filter???
Oct 16, 2009. 11:17 AMBOOM5601 says:
No.
Oct 6, 2009. 7:02 PMGalaxyX says:
about how long estimated would it take for the liquid to evaporate in the ammonium nitrate/ sodium hydroxide method?
Sep 27, 2009. 1:01 PMheat700 says:
why was it bubbling up like solder when u lit it?
Jun 12, 2009. 5:57 AMminerug says:
can this be used for smoke bombs?
Jun 12, 2009. 11:47 PMminerug says:
Thanks
Jun 12, 2009. 5:43 AM___ says:
(removed by author or community request)
Jun 12, 2009. 10:44 AM___ says:
Jun 9, 2009. 7:57 PMcor0018 says:
When you say "Once it's boiled, leave it to evaporate until dry." do you mean leave it on the heat or just let it sit until its dry??
Jun 12, 2009. 5:59 AMminerug says:
And, you might be able to capture and condense the ammonia gas so you can make other stuff
Jun 3, 2009. 9:20 AMkiller12 says:
i must be stupid , cause i dont get it!!!!
Jun 2, 2009. 2:43 AMpryrofreak119 says:
which is better sodium nitrate or potassium nitrate
May 16, 2009. 3:48 PMGlueyMcGee says:
can I just use sodium bicarbonate from baking soda I buy at the store?
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
613
Author:NurdRage(NurdRage)
NurdRage is a dedicate group of science nerds trying to further amateur science with direct how-to instructions in video format. We saw what was already online and we thought "we could do better"... s...
more »
