How to Make Solenoid Engine
22,457
70
6
Published
Introduction: How to Make Solenoid Engine
About: Electrical engineer by profession
Hi friends
this time i will show you how to make a simple solenoid engine.
It is very fascinating to see how physics works, with this project we will see how magnetism works to rotate a wheel,
here linear movement of solenoid is convert into circular motion.
Step 1: Video of Solenoid Engine
First please have look on video to see how solenoid engine works
if you like our work don't forget to subscribe
https://www.youtube.com/channel/UCsOFElmDD3e8l-RGC...
Step 2: Material Required
As you can see i have mention each and every information in image itself with dimensions and details
followings are the list of material
1) A acrylic sheet 13 x 14 CM used as a base
2) Solenoid Coil (how to make this coil i will cover in next step )
3) A crank shaft made from strong iron wire ( bicycle tier spoke)
4) Nut bolts as required
5) Some pieces of strong wires dimension are mention in image
6) A wheel (wheel must have some weight to gain momentum)
7) Some pieces of electric wires
Step 3: How to Make Solenoid Coil
I use thin copper wire of around 36 AWG
Bring a straw or strong plastic pipe of around 5mm diameter
Start wound copper wire along the length of pipe in uniform way i keep the length of solenoid 4.5 cm
Wound around 500 to 600 turns uniformly on pipe.
now remove insulation from both the end of winding by burning both end in flame
so you solenoid is ready to connect with power supply
some thumb rules of solenoid
the strength of solenoid is directly proportional to the number of turns & inversely proportional to the length of solenoid.
means number of copper wire turns increase the solenoid strength
& longer the solenoid length weaker the strength
Step 4: Procedure
It is advisable to watch once the video for better visualization
1) place the crank shaft support on the both side of acrylic sheet
2) Place solenoid coil on the solenoid stand
3) I use a drill bit as a plunder of solenoid
4) connect plunger extension shaft
5) connect this shaft with cranks shaft
6) Make a arrangement like when plunger is extremely out from solenoid, solenoid get power and pull plunger in
7) by repeating this continuously your engine start rotating
5) I used 12V DC power source
I hope you like this
thanks for your attention friends
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    5 Questions
    How to calculate the number turns and power required..can u give me off for calculation..na wt type of gauge I should use...and is Der any procedures for making crankshaft plz send me pdf to ma email.kiranvki25@gmail.com
    Can we take more than 12volts??
    Can i use 9v batery with same coil?. And can i make this for my physics project ?
    Can you please show a circuit diagram how everything is connected to each other.
    6 Comments
    Can i use 9v battery with same coil? And can i make this for my physics project ?
    my crankshaft do not rotate . what should i do??
    shape it(crankshaft) well and shape of wire which is touching half circuit is also depends
    this is my email can u send me in pdf please
    email: renashessen@gmail.com
    clever use of the axle to complete the circuit! I made a solenoid once but the wires got very hot and melted the plastic tube. How much current is running through the wire?
    reason is less number of turns of coil,
