How to Make Super Bright Flash Light With LED - DIY: Super Bright Light
Published
Introduction: How to Make Super Bright Flash Light With LED - DIY: Super Bright Light
About: Subscribe Here: https://www.youtube.com/channel/UCJoXoKcfAo4j9XWDlxCWMyg
Watch the video At First
Step 1: 4v LED Strips As LED
you can buy LED stips from here.
4v LED Strip + 4v Battery : https://ouo.io/gLQW3y
Step 2: Connection
Connect 2 strips in parallel.
Step 3: Double Sided Tape for Fixing
You can get it from here
Link https://ouo.io/Iyln6B
Step 4: Battery
For the cost-cutting, I have used 4v Lead Acid Battery.
You can use lipo or 18650 battery With Protection Board
Here is
3.7v Li-po Battery Link https://ouo.io/Zk4mpj
https://amzn.to/2rXZkiz
18650 Battery Link https://ouo.io/bNQnrm
https://amzn.to/2KEfEwI
Protection Board Link https://ouo.io/tJ5s2T
https://amzn.to/2rVIRfE
Step 5: Attachment
Attached the LED strips on the Battery.
Step 6: Box for All Components
Switch Link https://ouo.io/oj3UYkK
https://amzn.to/2rVWRpS
micro USB ** Bought it offline
Case **Old watch case
Step 7: Circuit Diagram
Step 8: Turned on the Switch
See the Bright Light
Sufficient For anyone.
Step 9: Charging
I am charging the Light With PowerBank Now You can See The White LED is on While Charging So it Means It Is Charging.
Step 10: Use While Charging
You Can Use the LED Light While it is charging.
Step 11: Watch the Full Video & You Will Understand Every Thing
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    Can You Say What Extra Component I Have Used in Circuit Diagram Which is not Essential ?
