How to Make TDA2030 Amplifier- HiFi AMP
1,261
4
Posted in TechnologyAudio
Introduction: How to Make TDA2030 Amplifier- HiFi AMP
About: I'm nothing but zero without my Arduino... Btw feel free to ask me anything . Contact me in facebook: facebook.com/Ashiqagent ....Here is my international cell ph. no. +88-01760722456
Click here to watch video tutorial of making TDA2030 amplifier
Hey guys , how are you ? Hope you're all well . From very long time I've been waiting to upload this video . But as I didn't have so much time to upload it. I'm so so sorry for that .but now I'm here with the latest video . In this video we'll watch a sound test or you can say it a bass test of a Power Amplifier IC called TDA2030a . TDA2030a: TDA2030a amplifier IC is so popular in the electronics amplifier market . Because the quality ,cost efficiency & the output power factor . It works so well however the voltage is not in required level . And the bass is also satisfying . We may compare so many power amplifier IC to this one like STK4141, LA4440 and so on . But this one is really the great , It contains 5 working pins . It also requires a heat sink must . Cause as this IC produce lots of heat so must have to connect heatsink .Otherwise your IC will be burned out . So be carefull about this . It gives about 10watt RMS as the output power which is quite satisfying for a low budget mini audio amplifier . And the input voltage level is around 8v-18v. Iused 12v-3A here . And the most important thing is it requires the input voltage biasing .That means it need both positive (+ve) & negative (-ve) supply to turn on . And a ground pin also . But if you modify the circuit diagram for single power source then it'll be okay for you . Then you can go wih the single power supply . Okay . I hope I gave you some important tips about making TDA2030 amps . If I'm requested then for sure I'll make a tutorial video that "How can we make a mini amplifier using TDA2030a IC" . Here is my facebook link https://www.facebook.com/Ashiqworld . You can text me there anytime for any kinda help . I'll be ready to help you if I know thematter or term correctly . Otherwise I'll provide you websites to make it easy for you . Here is my Educational Website link: http://www.amaderelectronics.com/auth... Follow me on #Twitter : @AshiqagentsThank you everyone for watching this video . If you like this video give a #Thumbs_Up & don't forget to #Subscribe this channelfor more upcoming videos about electrical solution . I'll be there for you guys to help . Adios . Ta Ta . Bye Bye :)
Step 1: Watch This Video to Complete Full Project
I added the video link with this instructables hope you'll take a look
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    For what its worth the TDA2030 appears to be obsolete now, though some distributors still stock it.
    The TI LM675T and LM1875T parts have the same pin-out and are functionally very similar so should require minimal circuit changes.
