How to Make Time Lapse Videos With Canon EOS DSLR
Introduction: How to Make Time Lapse Videos With Canon EOS DSLR
Time-lapse is a photography technique that the frequency of frames captured is much lower than the frequency those captured frames were played back. Time-lapse creates a unique experience for the audience and is widely used nowadays in movies, commercials and so on.
Here is an example of a time-lapse I have created for this Instructable:
Before we begin, please note that this Instructable is primarily focusing on Canon DSLR users with the Magic Lantern firmware installed. However, I am using Magic Lantern just as an Intervalometer and you can finish this Instructable with a hardware Intervalometer as well. I will briefly mention how to finish certain steps with an Intervalometer as necessary.
The time it takes to finish this Instructable is variable. But in general you will need 5-10 minutes to finish the setup and 20 minutes to compose the video. Plus times needed to actually take the frames using the camera.
Also, please note this is not an elementary guide on how to shoot photos with a DSLR. The author of this Instructable assumes you have basic knowledge on how to operate your camera such as changing the aperture settings, shot speed and ISO.
Step 1: Prepare Necessary Tools
To make a professional feeling time-lapse video, you will need the following:
  • A Canon Camera with Magic Lantern firmware installed
    • The steps for installing Magic Lantern on your camera could be found at: the official Magic Lantern Wiki.
    • In case you do not want to install Magic Lantern on your camera or you have a non-Canon DSLR, an Intervalometer will be required.
    • Make sure your camera's battery is fully charged before continue. Since your camera will be kept on for a long period of time while taking the frames.
  • Tripod
    • Tripod is almost always needed while taking time-lapse videos. Since even the slightest shake will have significant effects on final video.
  • Video Editing Software
    • You will need a software to convert photos we took into a playing video. There are multiple choices for this. In this Instructable I will be using Adobe After Effects as an example.
Step 2: Setup the Camera
  1. Compose a great shot. Think about what you want your time-lapse looks like and find the appropriate location for achieving that goal.
  2. Setup the tripod on a stable platform.
    WARNING: Setting up tripod on an unstable platform possess the danger of damaging your equipments.
  3. Turn the mode dial of your camera to M (manual).
  4. Turn the focus mode switch on your lens to MF (manual focusing).
  5. Set appropriate aperture opening, shot speed, white balance and ISO setting. Once set, those value should not be changed throughout the shooting process.
    Tip: Setting the camera exposure and focusing settings to manual will keep your time-lapse video shake/zoom/blinking free.
  6. To test you have the appropriate settings, take a few photos while the camera is still in your hand and confirm the result is desirable.
Step 3: Mount the Camera
  1. Securely mount the camera on the tripod and make sure it is stable.
  2. Turn on the Live View mode to help you adjust the pan and tilt, as well as zoom and focus of the lens to achieve optimal image.
    Tip: Use the Zoom In button found on the top right corner of your camera to help you adjust the focus.
  3. Once you are happy with the preview result, quit the Live View mode by pressing the Live View button again.
Step 4: Begin Shooting
  1. Press the trash button to open Magic Lantern menu.
  2. Navigate to "Shoot" submenu with the upper dial.
  3. Use the lower dial to reach the "Intervalometer" item and press "FUNC" button to enter.
  4. Set the Interval to "10s" using the lower dial.
    Tips: The shot interval depends on how smooth you want your video to be. Generally 5-10s are considered as reasonable setting.
  5. Hit the trash button again to quit the Magic Lantern menu. Your camera will begin taking photos every 10 seconds.
  6. Wait until enough photos has been taken. Then press the trash button again to stop the Intervalometer.
Note: If you are using a hardware Intervalometer, skip steps 1-5 and just connect your Intervalometer to your camera's remote control port as instructed in your owner's manual. Set appropriate intervals on your hardware Intervalometer and start the timer.
Step 5: Final Processing
  1. Import the generated sequence files to your computer.
  2. Open After Effects, Select "New Composition".
  3. Put in an appropriate name for the Composition and select appropriate video size. In this example I'm using 1080p, 30fps.
    Tip: While you are free to choose pretty much whatever video size you want, there are no advantage on selecting a size that is bigger than your picture's size.
  4. Click OK.
  5. Right click on Project Panel, select "Import" -> "Multiple Files".
  6. Navigate to the folder containing your time-lapse shots and select the First File. Make sure the "Camera Raw Sequence" checkbox is checked.
  7. Click "Open".
  8. Confirm the sequences has been successfully imported into the project.
  9. Drag the sequences to the preview window to add the sequence to the composition.
  10. Right click on the timeline, select "Transform" -> "Scale" to scale the picture to appropriate size.
  11. Click "OK".
  12. Once you are happy with what it looks like, click "File" -> "Export" -> "Add to Adobe Media Encoder Queue" to openAdobe Media Encoder for final encoding.
  13. Click "Start Queue" to begin the encoding process.
  14. There you have it, your first time-lapse video using a DSLR camera. Share it on Youtube with your friends!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    Thanks for the easy to understand instructions. Any reason to shoot in raw for 1080p video? It takes a lot of storage and CPU power for post processing. Wouldn't jpg in a lower resolution do the job too?
    Wow! That turned out looking amazing! Thanks for sharing you technique and welcome to the community!
