3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Tofu
How to Make Tofu
Tofu is great in so many recipes and easy to make. Along the way you will also make soy milk and have some okara left over. Okara is basically just bean pulp but it is great in breads, burgers, or cookies.
Step 1What you will need.
What you will need.
Ingredients:
You'll need water, 3 cups of dry soy beans and 2 TBSP of Epsom Salt. As an alternative to the Epsom Salt, you may use 75ml of lemon juice. Most of the nicer grocery stores will have the soy beans and you can find Epsom Salt at the pharmacy.
Equipment:
Food processor or blender, 2 large pots, 1 colander, 1 strainer, and a mesh bag. Instead of the mesh bag you could also use a few layers of cheesecloth.
*Also note this recipe works doubled.
94 comments
1-40 of 94next »
Mar 18, 2012. 10:45 AMOwlherder says:
Thank you for making this Instructable. I've been making tofu this way for years. My brother made me some 4 sided wooden molds (no top and no bottom) made so that the resulting block of tofu will fit nicely into my Tupperware storage container, close in size to store-bought tofu blocks.
Set mold into a pan to catch the drainage, line the sides and bottom with strips of muslin, pour in the curds, place small block of wood on top (cut to fit inside the mold frame) and a couple of cans of food from the pantry on top of the wood block.
I just store my molds, muslin strips, home made straining bag all in my large canning pot in the garage. Everything is all together when I'm ready to make tofu.
Mar 7, 2012. 9:46 AMpiggie1230 says:
Do you ever save the drained milk? I imagine that it would be salty, but if you make it with lemon juice ... my braid keeps saying this should be very much like butter milk since it is essentially the same thing.
Jan 22, 2012. 10:57 PMhusejn says:
would this recipe work with other types of beans?
Oct 12, 2011. 1:32 PMpschuppan says:
If any of you are concerned about using EPSOM Salt (MgSo) in tofu for a coagulant, don’t be unless you have an allergy to such a thing…. It is safe to add to food, and is chemically very similar to the Japanese tofu coagulant NIGARI (MgCl2), but is cheaper and easier found in the United States…..
EPSOM Salt has been used in this country for generations, and is still today a Doctor’s recommended home-remedy that can be used SAFELY both internally and externally for several things …. Did you catch the “Doctor Recommended” ….. EPSOM Salt is after all a salt, and as with any salt, it is never recommended to be taken internally in large amounts, so do your research (google), and don’t go over-board, you don’t need much.
As for the final product, and if my knowledge of basic chemistry serves, my guess is most of the salt and magnesium would be left behind in the by-product liquid solution discarded after straining out all the tofu curds, but some would remain in the final product as a supplement. I know the Chinese culture uses a coagulant that contains Calcium, and therefore does contain more calcium than other versions.
Nigari, not Nigiri (which is stuffed rice triangles) and EPSOM Salt are chemically similar, but not exactly the same, and therefore you cannot substitute one for the other in the same ratios….. the amount needed for using NIGARI (MgCl2) is much less then what this recipe calls for.
Both are considered “Bitters”, so experimenting with the LEAST of either coagulant resulting in best product is key to avoiding a bitter taste.
I too took out about half (6 Cups) for other uses, and left the remaining 8 Cups for tofu.
Knowing I needed less of the NIGARI, my husband and I determined 2 tsp dissolved in ½ cup water might do the trick.
I also saw the YouTube video where the women making the tofu used a separate container (larger then the other) to quickly drop-pour the hot Soy Milk into the other pot containing the dissolved coagulant (I placed my receiving pot on a clean towel on my clean kitchen floor). I gave it a swirl put the lid on, and left it for 10 – 15 min….. it worked great, and made 18.2 oz of tofu.
In this recipe it was not clarified if you need 2T of Epsom Salt for a full batch or just the half of the batch of soymilk he made into tofu…. I assume it was for a full bach, and you can nock the Epsom Salts down to 1T for a half bach, but I suppose that’s another experiment…..
As far as Costs:
4lb bag of dried Soy Beans ($5.95) found at my local Asian market works out to $1.49/pound for comparison shoppers. 4lbs of beans measure approx 10 Cups equaling $0.60/cup. 3 Cups/Batch = $1.80 plus Nigari, Epsom salt, or lemon…. Throw in $0.25/batch for an estimated total of $2.05/batch.
Each ($2.05) batch produces:
(A) Approx 3 pounds of OKARA to add to recipes, plus (B) 14 Cups of Soy Milk = 3 Quarts plus 1 Pint …. Almost shy a gallon
Or
(A) Approx 3 pounds of OKARA, plus (B) 6 Cups of Soy Milk = 1 Quarts plus 1 Pint, and (C) using 8cups of Soy Milk = 18.2 oz or just over 1 lb of tofu
Or
(A) Approx 3 pounds of OKARA, plus (B) using 14 cups of Soy Milk = approx 32 oz 2lbs of tofu.
**** Most bricks in the store come in 8oz, this recipe if used only for making tofu would equal 4 regular size tofu bricks (and with the additional bonus of 3 pounds of Okara, which I may use 1:1 with beef in tacos or meat loaf to stretch a meat/protein dollar) for only $2.00 is worth the work in my book.
Oct 13, 2011. 1:15 PMpschuppan says:
Here is another great site for tofu making.... and using nagari
Part 1: Making Soy Milk
http://www.justhungry.com/2006/03/milking_the_soy.html
Part 2: Making Tofu
http://www.justhungry.com/2006/03/milking_the_soy_1.html
Part 3: Using Akara
http://www.justhungry.com/2006/04/milking_the_soy.html
Oct 13, 2011. 12:28 PMpschuppan says:
Experiment #1 with tofu made with nigari instead of epsoms salt was partially successful..... the texture was perfect, the taste too bitter.... next batch I will use 1/2 of what I used and post my findings.... "less is more"
Oct 12, 2011. 9:16 AMpschuppan says:
Hi, your instructions are very good. if anyone is concerned about using epsom salts (MgSo), don't be.... it is safe to ingest in small amounts such as this recipe, actually adding nutrients to the product, and has long been used for internal and external medicinal purposes, and plant food for tomatos. Google it if you have any further conserns. It is a very simillar chemical coagulant used in japanese tofu called nigari (MgCl2), not to be confused with nigiri (rice)
Sep 15, 2011. 1:07 PMsacarlson says:
Some comments from my experiences.
1. I use about 1 lb of dried beans and get at least 1 1/2 lbs of extra firm tofu.
2. I strain my okara before heating. I picked that up from a youtube video and it makes it less likely to over flow the pot
3. Please pay close attention once the temperature gets above ~160F. Stir a lot to keep it from rolling over the pot.
4. I dissolve my nigari in another pot and pour the cooked milk in all at once from about 2 feet high. May seem odd, but this caused a very even mixture and I get a very consistent curd when it sets. No uncurdled spots.
5. I sewed my own straining bags and pressing bags from muslin, to fit the containers better.
6. I use the okara to make omlettes that even my kids love.
7. I clean the bags by boiling in water for a couple minutes once everything is done.
8. I have a pressing box (got it as a gift) and use 3 paver bricks as weight. They are wrapped in plastic wrap, and taped shut. I use one brick that was cut short (during my driveway project) first, as it fits in the pressing block
Sep 16, 2011. 10:16 AMk24tea says:
I just found your Instructable, a year after you posted it. Thanks for this! I have a question I didn't see addressed in the comments up to this date: Would you get the same results using soy FLOUR instead of soaking and then grinding the whole soybeans? Seems like soy flour would be a lot quicker (less time soaking) and easier (no grinding after soaking). I have both soy flour and soy grits, but no whole beans. It's a loooong way to buy them around here so I don't want to ruin what I already have. Is anybody using SOY FLOUR to make tofu?
Jun 22, 2011. 8:42 AMpaulie-tana says:
I am new to all this tofu stuff. Just wonder if you can make tofu from ready made soy milk from the supermarket.
thanks
Aug 11, 2011. 8:05 PMnachiko says:
I thought your idea is great short cut process. I tried but not successful. The soy milk I bought or coagulate amount was wrong ? It didn't curd enough.
I want to hear anyone succeeded using ready made soy milk from supermarket.
It is art of tofu making. Good things takes time, so I soak soy beans tonight !
May 12, 2011. 8:54 PMrazezar says:
For how long does the soy milk keep?
Feb 13, 2011. 9:48 AMfdcontre says:
the epsom salt give the curd any taste ?
Feb 8, 2011. 1:42 PMvishnupriyadevidasi says:
So, I'm making this today, what should I do, if after my ten minutes I don't get the curds? Should I add another 2 Tbsp of Epsom salt in warm water and mix?
Feb 8, 2011. 3:53 PMvishnupriyadevidasi says:
Thanks. It worked. I also added the juice of one lemon.
Oct 4, 2010. 1:25 PMeaemeric says:
I got a very small amount of tofu after following this guide exactly, and I only took out one jar of soymilk. Is there anything that I could have done to cause this?
Oct 6, 2010. 5:08 AMeaemeric says:
The water was yellow-ish clear, and I measured out the beans. However, looking at some pictures more closely, I don't think I ground them fine enough before letting them simmer, which might have something to do with it. I'll re-try and let you know.
Sep 29, 2010. 4:46 PMLocketRocket says:
Wow great instructable. Can you also subsitute apple cider vinegar for the epsom salt?
Sep 12, 2010. 6:45 AMmamaof7 says:
ok my question is answered here, maybe I should read right through next time lol
Sep 23, 2010. 2:18 PMdarkknight671 says:
Or just skip the reply... There is a cancel button.
Sep 20, 2010. 7:15 AMKaycey1 says:
Why epsom salt and not regular salt?
Can I use sea salt instead?
Sep 16, 2010. 5:37 PMkaykatz says:
I recently won a soymilk maker and will be making tofu using your clear, concise directions. Thanks!
Sep 12, 2010. 6:44 AMmamaof7 says:
So the soy milk, could I use that as well? (we drink soy milk in our house)
Sep 14, 2010. 3:23 AMthayray says:
I've made soy milk many times. I do it the same way as you except I go through the process twice, as there's still a lot of milk to get from the "okara" after the first batch.
When my wife and I made tofu, we found the first batch of milk too strong, so we used all the first batch for tofu. The second batch (with a little sugar) was perfect for drinking milk.
p.s. We used lemon juice and not Epsom salt, it worked well.
Sep 16, 2010. 5:52 AMthayray says:
I didn't measure it but quite a bit more than 2 tbsp. Same way as we make cheese, with the milk good and hot we keep adding lemon juice till it condenses. The lemon doesn't really affect the flavor of the cheese/tofu.
Sep 15, 2010. 8:53 AMslowcooked says:
If you use Gypsum, aka Terra Alba, you will get a nice boost of Calcium.
Epsom salts are somewhat laxative, whereas Gypsum isn't.
Epsom: Magnesium Sulfate
Gypsum: Calcium Sulfate
It is easily found at Home Brew shops as it is used to configure ion content of the brew water.
Sep 14, 2010. 10:27 AMKaycey1 says:
How long is it good for?
This goes for both the milk and tofu
1-40 of 94next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:mikeinternet(Electronic Instruments)
