How to Make Touch Switch Using 555 Timer IC | DIY | Homemade | Basic Electronics Projects
Published
Introduction: How to Make Touch Switch Using 555 Timer IC | DIY | Homemade | Basic Electronics Projects
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today In This Tutorial I Am Going To Show You Step By Step ( Home Made )
How to make Simple Touch Swithc Circuit Using 555 Timer IC Simple Electronic Project Home Easy DIY
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
Please Subscribe ↪ https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
Step 1: Hardware Required
  • +4 to +6 supply voltage
  • 555 IC
  • 470Ω, 100KΩ resistors
  • 10µF, 100nF (104) capacitors
  • LED
  • Touch plat
Step 2: Circuit Diagram
Step 3: Working Explanation
The above figure shows the circuit diagram of touch switch.
The voltage supplied in this circuit must not exceed 6V, doing so will result in IC burn out. The capacitor between pin6 and pin1 determines the turn on time of LED once a trigger is passed. This circuit can be modified to turn ON for 2minutes for a single trigger by replacing the 10uF capacitance with a 1000uF one. So with the capacitance change one can get many turn on times and so can make the use of this circuit as a stair case lamp.
Working
As shown in the below video, the touch switch circuit is connected on the breadboard as per the schematic diagram, and power is turned ON. Now the LED will not turn on as the trigger is not given. The trigger pin in the timer is a high impedance one and is very sensitive. This pin can merely be pulled high by human body potential. This trigger determines the output of 555. This trigger pin SETS the flip-flop inside the 555 TIMER. When this pin is high the output will be high and when this pin is low the output is low. As said earlier since this pin is very sensitive it will pull the 555 output high by touch.
So on touch the trigger pin forces the internal flip-flop to SET mode and so the output goes high. However this high stage can’t be retained for long once the trigger is removed. Once the touch is removed the high stage of output merely depends on the charging time of the capacitor connected between pin6 and pin1.
The capacitor, once reaches a voltage level it discharges through the THRESHOLD pin (pin6) of 555. The trick is, the Threshold pin is set up internally to reset the flip-flop. So on capacitor discharge the threshold pin goes high resetting the flip-flop which is set HIGH by the trigger pin and so the output also goes low with it. Hence the LED turns off at capacitor discharge.
So once the trigger is given the turn on time of the LED depends on the charging time of the capacitor. This turn on time can be increased by connecting a high value capacitor. With enough capacitance this circuit can put up a turn on time of minutes.
Step 4: Datasheet
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
