3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Writing appear longer.
This is a neat little trick to make text in a word document appear to be longer. This is great if you don't have a lot of time to make something look longer. What we are doing is replacing the periods in the paper to a bigger text size. This makes it look as if you wrote more than you actually did.
Step 1Find And Replace
Find And Replace
After you have your paper open, with out selecting anything push "control + F".
94 comments
1-40 of 94next »
Feb 24, 2009. 1:27 PMPKTraceur says:
Wow! My one page zombie essay was extened a quarter page, and It had exactly 100 periods. Schweet! -RoAr
May 26, 2008. 6:59 PMmanonfire285 says:
another good tip is to put two spaces after each sentence. if you do it consistently, no one would notice. for this, just use the replace function. find what: . (with one space) replace with: . (with two spaces) optionally, you can also use the font change. basically, do the exact same thing as this instructable, except with the spaces tip I just gave you.
Feb 17, 2009. 2:24 PMTorinMiasma says:
Great tip. I was taught in several of my lit classes that you are supposed to add two spaces after every period. For three years I had that drilled into me. Some of the handbooks also say that that is proper form. Using these tips in conjunction with one another works wonders... unless your teacher grades the papers on her computer... then you can be caught and it go on your permanent record that you cheated...
Jun 3, 2008. 8:58 PMeat_squids says:
One thing that I find that is quick and easy to do is, if you only need it to be a bit longer, increase the font by .5. This lengthens your writing, but won't be noticeable if you are given a certain size to use.
May 22, 2008. 10:15 PMmoleyscioly says:
The only thing the period trick does is change inner line spacing from whatever the original period font was to the new period font. If you are going to do this trick, you might as well just increase the between lines spacing.
Jun 25, 2007. 12:06 AMjeasterl says:
a tip from someone who worked in a English writing lab for over thirteen years first never write on a teachers 'pet' subject find out if the instructor is into poetry don't write on poetry if you can at all help it if they are into Shakespeare avoid that ect second look for a wider then normal font or bump up the character spacing by five or ten percent
May 19, 2008. 3:31 AMmwwdesign says:
It wasn't you that worked in an English lab, was it? There are over 10 mistakes in grammar and/or spelling in your short 'paragraph'.
May 19, 2008. 6:08 AMjeasterl says:
this is not a paragraph. this is a pair of informal tips,written in a spare moment. if my grammar errors offend you feel free not to use my tips, write on a professors "pet"subject, since you are smarter then me and have time to write smarmy comments instead of useful input two new tips (written in an informal style) read shrunk and white (sp) a simplified english handbook, it is one of the simplest most understandable grammer texts i have found read Sun tsu "The Art of War" this small text will teach you stratigies and methods of dealing with all sorts of difficulties.
May 19, 2008. 7:04 PMmwwdesign says:
You just topped your previous best with over 16 mistakes. Sorry, it's just that your boasts about working in an English lab for thirteen years seemed strangely at odds with your poor command of the English language. Yes, Art of War is a good read, but I haven't read 'Shrunk and White'. Thanks for the tip. :)
May 19, 2008. 8:30 PMjeasterl says:
maybe I should have been a little more specific my expertise is in computers, hardware and software, I have years of experience training instructors and students in the use of word processors and page layout applications, I also helped students with research. my tips in the first post only pertained to subject selection and font selection, things I am well able to do, not grammar if my tips were about grammar your comments might have weight but since they have nothing to do with grammar your post is without value tips in word under format-font-character spacing click spacing- expand and slowly bump up the spacing of all the text just a little 1.2 or 1.4 don't get carried away or it will be obvious as little as 1.1 can make a half page or more in a document without looking off and if found you can blame the word processor "but professor that is the way my program defaults" proper citation of referenced materials can 'bulk up' a short paper one good long quote can add a third of a page or more but remember to set it up according to the standards for your class a paper well written,on a unique subject, or with an unusual angle, and a bit short will almost always get a good grade where as a paper full of errors or a tired subject that is a chore to read will almost always get a lower grade. Note this is only true for instructors that read and grade by content some teachers grade by weight if you find a teacher that grades by weight run do not walk away they are mostly tired and will not really teach you anything. writing tip when writing a paper always always write an outline even if it is only a scratch outline if your word processor highlights errors do not go back and fix them as they appear wait till you come to a natural break in your thought process if you stop at every error you will lose your train of thought
May 20, 2008. 10:00 PMmwwdesign says:
Fair enough. Your tips are good ;)
May 19, 2008. 4:44 PMlunchboxslayer27 says:
I need to write an essay for a roller coaster i needed to build FOR 6TH GRADE!!!!!!!! i think thats a really stupid project. but this will help with the essay. thatnks!!!!
May 20, 2008. 2:06 PMlunchboxslayer27 says:
just describing like g's and ur roller coaster, and like wut its name is. teach wanted full page. well i gave it 2 her. with this!! thx!!
May 19, 2008. 4:21 AMawkrin says:
that could of been done by increasing the space between lines by selecting all the text, righrclicking and going to font, and increase the space either after a line, or before it. saves more time!
May 16, 2008. 3:35 AMjraregris says:
Why wouldn't you just change the line height? You're text will look inconsistent if you've got a setence that spans more than one line.
May 15, 2008. 6:51 PM__-_-_-__ says:
old stuff. that's why long time ago in my college all works must be formatted with specific letter size etc etc etc
May 29, 2007. 6:56 PMbobbyk881 says:
easy way double-space. ps. nice instructable. bobbyk881
Apr 9, 2008. 9:58 AMsman17 says:
now a daays teacher scan spot this easy.
Feb 24, 2008. 10:59 AMPumpkin$ says:
o.k so let's say you have a teacher who has tought in a middleschool, and highschool, AND COLLEGE will they notice it? I looked at it and it looked fine
Feb 24, 2008. 11:14 AMPumpkin$ says:
sorry for double posting but how do you make it normal again?
Jan 22, 2008. 12:10 PMNotbob says:
All I do is if my teacher saya size 12 font I put size 13. No one can tell the difference!
May 29, 2007. 11:37 PMdevilwyrm says:
seen this before on another site a while ago
add length to papers
Sep 9, 2007. 5:51 AManiketpatil says:
I have a better method my friend, increase the spacings between the two lines or simply increase the font size. Hehe. But still thanks a lot, i wasn't aware of this possibility. Thanks again... :)
Dec 2, 2007. 12:24 PMBrennn10 says:
Haha, this is a great idea, but risky!
Sep 21, 2007. 3:47 PMsmoke says:
I may be wrong here, but by changing the font of the periods to 14, the line spacing adjusted to 14pt spacing. But only on lines with a period. That means if you end up with a line with no periods (long sentences) the spacing will be 12pt and may be notecable giving yourself away. My high school teachers would have caught this, all of them told you exactly what font and size you had to use on each writing assignment, that was 10 years ago, having them all togeather made it very easy to tell if someone was trying to pad their work. Unless you let the whole class in on this so every ones paper appears the same, the failing grade you may recieve for trying to pull one over on the teacher may not be worth the extra time it would take to just repeat something and call it off as a stupid mistake. As an instructable though, you did have precise, orderly instructions.
Dec 1, 2007. 9:23 PMdenilsonsa says:
I was also concerned about lines without periods. And, hey, if you just want to increase the space, you should change the line spacing (which must be somewhere in the paragraph style settings) to something slightly larger than your current line spacing (like someone else suggested).
Nov 1, 2007. 11:13 AMRainbowlaces says:
My high school teachers were the same way. However you can squeeze a little more out of your words by increasing the spacing between letters (if you do it too much it's very noticeable) and pushing the margins in ever-so-slightly, in addition to, of course, having the space between lines be slightly more that double.
It's not good for much, but if you just need a little more it comes in handy.
Nov 1, 2007. 3:10 PMRainbowlaces says:
I wasn't saying it was a bad idea. I was just commenting that it probably wouldn't fly with the teachers I had. I guess I won't have the opportunity to try it 'cause I haven't been in high school for a while now!
Nov 1, 2007. 6:42 PMRainbowlaces says:
Haha. I'm pretty sure that when I have kids I'm not going to encourage them to cheat... :)
1-40 of 94next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:joejoerowley
My name is Joe. I don't use this site that much anymore because I am lame but you will find some my instructables from a while back that I wrote up. I'm really sorry if they are poorly written, don't ...
more »
