3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make XXL Street Stencils & Get Away WIth It
Step 5Scale up your letters
I have scaled up my letters using 2 methods. Using an overhead projector, and using math and a level.
Overhead Projector method
1. Print your letters out on transparency sheets.*
2. Project the letters against a wall with an overhead projector.
3. Hang the plastic sheeting against the wall where the projection lands.
4. Trace your letters with a permanent marker.
*Depending on the projector, you might need to print your original larger on the transparency in order for the letters to project 7 feet tall.
Math and Level method
1. Since you printed your letters to scale (1cm=1ft) you can draw a 1x1cm grid over the letters and use that as a guide for hand drawing your letters onto the plastic.
2. Plot key intersection points onto the plastic.
3. Use the level as a straight edge and to ensure you are drawing at right angles.
4. Note that "round" letters like S, O, C, Q, etc extend slightly above and below the "square" letters.
5. Don't worry if you are off by an inch or two, but try to be as exact as you reasonably can.
Cut out the letters.
On each plastic letter, note in permanent marker what letter it is and how far to space the next letter. Write the same note in several places on the plastic. When you're on the street, it's easier to find your notes than to roll out each 7 ft letter and see what it is.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:slambert(Visitsteve.com)
Eyebeam OpenLab Research and Development Fellow 2006-2007, Eyebeam Senior Fellow 2007-20010 You probably have seen his work already and don't know it. Check the site.
