3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Your Own Pill Towels, With Soap!
You might have seen these handy Pill Towels http://www.thinkgeek.com/geektoys/japanfan/b235/ at ThinkGeek.
When i saw these, i though they might be useful, but the 10 dollar price tag turned me off.
Here's how to make your own from thing lying around the house.
You can even throw in something extra!
Step 1What You Need
What You Need
For this project, you will need:
A film canister
A paper towel
Scissors
Water
A piece of glass Tupperware
Your hands
31 comments
Mar 29, 2009. 6:30 PMPatchIsCooking says:
I might be wrong, but aren't the ones on Thinkgeek made of cloth? I've gotten full sized towels like this before. Would love instructions on how to do this with a cloth towel. Would be great for emergency kits.
May 12, 2009. 2:11 PM142400 says:
if you had a gash or dirty scratch you could use peroxide instead of water to open the towel
Mar 31, 2009. 1:09 AMstrmrnnr says:
You might try to sent up a - plastic bag - plunger in the canister (small hole in bottom to help drainage and push the dry cloth out) - vacuum arrangment to compress the cloth and extract the water. That would be the most compact you could get the cloth.
Mar 31, 2009. 1:24 AMstrmrnnr says:
Sorry for the multiple replys on this. The ideas are rolling tonight. If you use the vacuum pump you will likely not have to use more then a few drops of water. Maybe a 50/50 with a liquid soap would do. Not sure how well the liquid soap would hold the cloth together. Another idea may be to mist the cloth with a spray bottle of a dry soap/water mixture before stuffing in a tube.
Mar 31, 2009. 1:11 AMstrmrnnr says:
Here is a link to a neat, small, pump conversion I saw on here.
http://www.instructables.com/id/convert-a-tire-inflator-type-air-compressor-into-a/
Mar 29, 2009. 11:14 PMLance Mt. says:
they are cloth... liek the washing up ones
Mar 29, 2009. 7:13 PMnave says:
yeah, and to make the towel bigger you have to apply water, but if you apply wayyer to this, wont it just kinda fall apart and be useless?
May 2, 2009. 3:11 PMstephenniall says:
think im gonna build these later
Apr 19, 2009. 9:16 PMporcupinemamma says:
Excellent! Thanks.
Apr 12, 2009. 9:01 AMnate121 says:
here try these they are smaller but a lot less expensive
http://www.survivalsolutions.com/store/product350.html
Mar 31, 2009. 8:38 PMberky93 says:
you could probably make one similar to this with a wash cloth an a vacumn bag...
Apr 6, 2009. 12:45 PMits a lion says:
That's originally what I thought was going to be used.
Apr 1, 2009. 7:26 PMDarren. says:
whats the point of this?
Apr 2, 2009. 5:07 PMskidude28 says:
Oh for God sake, if you read anything: They are small easy to store compact useful you can carry a lot take up very little space etc.
Mar 31, 2009. 8:50 AMsectheatre says:
Could be good for camping, especially tight resource motorcycle camping.
Mar 30, 2009. 6:00 PMLemonLily says:
What is it for?
Mar 30, 2009. 6:16 PMosgeld says:
you cary these dry disc's around with you, and when you need soap and a little wipe you just add water, it fluffs out with soap embedded, and your good to go
Mar 30, 2009. 10:49 AMmerijnvw says:
Is this really useful And don't those things rot when they're wet. And by the way when i was a little kid i made balls of paper towel, and let them dry, but then when i wetted them after they dried they became weak unhandy things. Wouldn't it be better to do it with a cloth tissue which you can wash? The only reason why it could be handy would be on a bycicle vacation.
Mar 30, 2009. 8:10 AMjustoskar1 says:
(from thinkgeek) You might not have ever stopped to think about it, but ninjas and astronauts have quite a lot in common. They both wear specialized clothing. They both can fly (though astronauts need a little mechanical help). And (most importantly), they both have to be very economical with what they carry with them, especially in regards to personal hygiene. That's why we suggest you carry some Japanese Pill Towels - to make sure you are always at your best. Each tube of Japanese Pill Towels contains 10 pills. Each pill is really a towel seed harvested in Japan. Just hold a pill under water and it blossoms into a multipurpose towel - perfect for cleaning your hands after each ninja or space mission. And if you want to be super clean, might we recommend also carrying some Dissolving Travel Toiletries (see related items below). Then you can make sure you are always as clean as your mind is. Ok, bad example.
Mar 30, 2009. 2:06 AMPlasmana says:
Very interesting, but, what are they used for?
Mar 29, 2009. 11:42 PMLance Mt. says:
Sorry for alot of messages, but for feedback sake "at a fraction of the cost!" is inaccurete! It HELLA CHEAP!
Mar 29, 2009. 11:33 PMLance Mt. says:
As awsome as this is, i'ming requesting somethign at least thinks of a way to make the "Dissolving Travel Toiletries"
http://www.thinkgeek.com/gadgets/travelpower/add9/
Even if you don't,
-Cheers, Chris
Mar 29, 2009. 11:13 PMLance Mt. says:
You I just had a look at the photo with the guy holding the pill towel at thinkgeek and it looks like one of those thin materials they use in washing up cloth... I inquired and it turns out you can make these on the cheap.. They had some off cuts and i think i'll be able to make 8 or so for the $0:70 (au) offcut
Mar 29, 2009. 10:51 PMLance Mt. says:
Sweet! I want to try the same with a towel and a bucket... Probbaliy fail! -(away trying),Chris
Mar 29, 2009. 7:34 PMhellstudios says:
I buy these at dollar tree.....lol
Mar 29, 2009. 4:48 PMj626no says:
which size is your personal preference for a size to function ratio?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jaxthecob
