Step 7Use it
-- Make sure that the object is not tapered on the bottom. This will make it impossible to get out of the plastic shell we are making.
-- Make sure that the entire object fits on the workspace leaving plenty of holes around the edges.
--Make sure the object can stand the pressure and heat of the process, otherwise they will deform or melt.
--Make sure the object is not too tall, if it is too tall, the plastic will be stretched too much, and become too thin to work with.
--Make sure there isn't too much detail on the object.
I chose the body of a tiny RC car.
Now place the selected object onto the workspace and put a spacer under the object so that the final product will look better. Use the vacuum cleaner's attachment hose to connect the vacuum cleaner to the 2 liter bottle top on the vacuum former. Heat up the plastic between the frames with a heat gun or hold the plastic over the burner of an electric oven until the plastic starts to get gooey and sag in the middle. HDPE plastic will turn from white to clear when its warm, this is normal. DO NOT use a gas burner; it will catch the plastic on fire which is not good.
10
comments
Add Comment
Add Comment
