How to Make Your Own Security Pins
Introduction: How to Make Your Own Security Pins
I show how to make security pins for pin-tumbler locks using common tools and materials. The pins are made by securing them in a drill or rotary toot and using needle files to shape the pin in a common or hybrid design. A security pin is a modified version of a key or driver pin in a pin-tumbler lock that makes manipulation more difficult. Security pins are commonly designed to prevent lockpicking, but are also designed to resist decoding, impressioning, key bumping, and other compromise techniques. Similar modifications to components in non-pin locks are also common, with serrated components being the most popular in both wafer and lever locks. Combination and disc-detainer locks commonly use false gates to prevent manipulation. You can add security pins to your locks that don’t have them to make them more secure.
Diagrams and Information:
- Security Pins:
- Pin-Tumbler Locks:
Step 1: Materials
- Needle Nose Pliers or Tweezers
- Needle Metal Files
- Small Clamp
- Drill or Rotary Tool
- Small Drill Chuck
- Key Pins and Driver Pins from a Lock
Step 2: How Security Pins Work
Security pins are designed so that use of a tool other than a key will trigger the pins and lock one or more pins at the shear line. This can be due to individual manipulation of components or tension on the cylinder. When triggered, security pins bind between the plug and cylinder, blocking the rotation of the plug until tension on the cylinder is released and pins are dropped back to their resting position.
Step 3: Watch the Video
(The video may not show up for mobile viewers)
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    You get a bunch of spare pins when you buy a lock rekeying kit at a hardware store. The kits are designed to rekey locks to match 1 key, for example so your front door, back door, and deadbolts would all use the same key. That's where I've seen the color coded pins shown in the photos, each color is a different length.
    Can you give a brief on the advantages/ disadvantages between the 3 pin variations please?
    3 pins, mean that you can master key it.
    Very nice! I only wish you had offered more guidance about when to use each type. Still, it is easy to follow and informative. Thanks!
    Hehe. Nice to make a lock without telling how to make the according key. That's perfect security!
    You can use a lock that already has a key. the key pins are kept the same and the driver pins can be changed to any of the security pins. you don't need to re-key the lock.
    Use the original pins from the lock and reassemble maybe - as long as the height and order of the pins in the lock aren't changed you can use the same key.
    Nice tip using the drill as a lathe - worth the instruct-able just for that.
    I will never use/build this but now I know how to use my drill as a lathe. I learn something new everyday...Thanks!
    Interesting. I never thought about making my own lock parts before.
