Introduction: How to Make a 12v Battery Pack at Home
Picture of How to Make a 12v Battery Pack at Home
How to make a 12v battery pack at home is an easy project based on multiple Li-ion batteries in series to create a 12v pack.
https://www.youtube.com/watch?v=xddY02m6lMk If you need a 12v battery and want to learn how to make it from 18650 cell watch the video it has details on how to make a new battery at home.You can make this battery from 18650 cell that can be harvested from laptop batteries or power banks, a thing that has Li-ion in it can be reused and reconfigured in a homemade battery
Step 1: Things Needed for the Battery Pack
Picture of Things Needed for the Battery Pack
You have two options one is to solder the batteries and then make your connection series or parallel or mixed
i have found that this 18650 battery holder works just fine and you can reuse them for other projects.
The important steps when making a 12v battery:
Charging the cells
Discharging and see the mAh of each battery
Match them to closed capacity
Make your battery pack by series or parallel connection
Parts needed for this project:
18650 cells
wires
Step 2: How to Make the Battery Pack
Picture of How to Make the Battery Pack
In the picture, you can see a very easy diagram on how to solder the wire
keep in mind that the positive + and negative - terminals have to have the same length
to keep the pack balanced that's a tip for future arrangements of combined series and parallel connection
Step 3: Inserting the Cells
Picture of Inserting the Cells
Is very easy we will alternate the cells when we gonna put them in the first cell up the plus + terminal
second, up part is gonna be the minus - terminal and the 3rd cell with the plus terminal upwards.
If you find this video useful like share and subscribe
https://www.youtube.com/channel/UCPjqH3HfNA4Shttkx1haAUQ Thanks for watching and see you next time all the best! Others electronic projects from NO Skills Required: Washing machine motor generator https://www.youtube.com/watch?v=_jKTsAJK8aQ Washing machine motor wiring basics https://www.youtube.com/watch?v=XlaHSZFGzp0 Washing machine motor speed control https://www.youtube.com/watch?v=lRj6V7ygBQo Incredible washing machine motor on battery https://www.youtube.com/watch?v=TcMUTqSvOsw
NoskillsrequiredN (author)2017-12-05
hubi (author)2017-11-22
Your idea is good, but dangerous!
First you should never use 18650 batterys or other LiIons, without a protection circuit.
Second: LIIons in series should always have a load balancer circuit.For examle three batteries in series need a 1p 3s balancer.like https://www.ebay.de/itm/3S-11-1V-12-6V-4-6-15A-186...
Those circuts you can find for cheap on Amazon AliExpress, Ebay and others.
About This Instructable
185views
4favorites
License:
Bio: Hello friends i show how to make stuff with no skills easy to replicate step by step from powerbanks,generator,invertors and so on thanks
More by NoskillsrequiredN:How to Connect Led to 9v Battery Using Resistors12v Battery Discharge Protection Circuit at HomeHow to Make 220v Touch Switch Light Using Relay
Add instructable to:
