How to Make a 24-bottle Wine Rack Storage Cube
Introduction: How to Make a 24-bottle Wine Rack Storage Cube
This easy wood wine rack build can be made for under $25 and holds about 24 bottles of wine. Build several cubes and stack them together to build your own personal wine storage unit, or build the smaller counter top version of this project that holds 12 bottles. Perfect for your kitchen, closet, den or basement. See for more information on this and other projects!
(Clicking the links below and purchasing anything on amazon helps support JDIY, and it doesn't cost you anything extra!)
Kreg jig
Miter saw
Orbital sander
Hand plane (optional)
Small clamps
Large clamps
Lumber & materials
Pine 1"x10"x12' (or two 1"x10"x8' boards)
Kreg 1 1/4" coarse screws
Wood stain
Wood conditioner
Step 1: Cut the Sides and Top of the Cube & Decide on Dimensions
There are two versions of this project, with everything being the same except for the ending size of the wine rack. See the diagram photos within.
A.) Larger 24-bottle wine rack, measures 21" square and 9 1/4" deep.
B.) Smaller 12-bottle wine rack, measures 16" square and 9 1/4" deep. Since the typical kitchen cabinet is 18" off of the counter, this smaller version is perfect for this space.
The outer cube will be attached using butt joints, so the sides need to be cut slightly smaller so that the overall exterior dimensions are 21". A 1x10 is approximately 3/4" thick, so the length of the sides should be 21 inches minus 1.5". Using a miter saw & cut the following:
Cut list:
A.) Large wine cube:
Top & Bottom (2x) 21"
Sides: (2x) 19.5"
B.) Smaller wine cube
Top & Bottom (2x) 16"
Sides: (2x) 14.5"
Step 2: Assemble the Cube Frame With Pocket Holes
First, clean up the end grain of the tops and sides with a hand plane so that the surfaces are flat. Then, using masking tape, dry fit the wine rack frame together. Mark an 'X" on the inside face of each of the side boards. Next, you want to mark where your pocket holes will go. Place the two side boards on a flat surface, with the marking facing down. Then, layout 4 or 5 lines, about evenly spaced across the width of the board. Transfer these lines to both the top and bottoms of each side board with a pencil.
Next, using your Kreg jig, set it for 3/4" stock, which is the thickness of a 1x10. Align the side board so that the marked face is facing you, then drill your pocket holes. Flip the board lengthwise and drill pocket holes on the opposite end of the board and repeat this process for your other side piece.
Once all the pocket holes have been drilled, assemble the frame by screwing a screw into each pocket hole. Make sure that the boards are square and not crooked and push down on the boards so that the screw will bite in. I've found that using a large clamp to push the last two boards into square was very helpful. You can add a small amount of glue to each joint to strengthen the pocket holes, but after I assembled it, it was rock solid.
Step 3: Measure the Wine Rack X Shelf & Measure Notches
Take a diagonal measurement from the inside corners of the cube. You should come close to 27.6" for the 24-bottle wine rack design and 20.5" for the 12-bottle design.
Cut a board slightly longer than that on the miter saw and check that it will fit within the cube snugly. If it doesn't fit at first, shorten it carefully with the saw until you get the proper fit. Then set your miter saw fence and cut a second board to the exact same length.
For math the math enthusiasts out there, another way to calculate the total length of the diagonal is to put that high school geometry to work, using the Pythangorean theorem. A^2 + B^2 = C^2
Measure and mark the center of one of the boards. Then, using a scrap piece that is 3/4" thick, center it over that line, making sure it is square, and mark that as well. Finally, measure the halfway point from the width of the board, (note that a 1x10 is about 9 1/4" wide). This mark out is the notch that you will cut out of each board so that they will fit together to form a very strong X.
Step 4: Cut the X Shelf Notches
Since both boards from step three are the same length and the notches are to be in the same place, you can cut them both at once. Clamp or tape the two boards together and use a jig saw to cut out the notch. Check the fit with a scrap board of the same thickness and use a sharp chisel or sandpaper to clean up any rough edges.
(I found out the hard way that my bandsaw didn't have enough clearance to make the cut, so I used a hand saw and chisels to form the notches. Jigsaw added to my tool wish list!)
Step 5: Final Fit & Finish
Fit the X shelf together and then check to see how well it fits into the cube. Use a hand plane to shave down the corners of any end that doesn't want to fit. Then, sand down all the pieces with 180 then 220 grit sandpaper. If you'd like to stain the wine rack and you are using pine, make sure to use a pre-stain conditioner. I used two coats of cherry stain on my wine rack cube.
Congrats, you've made it! Cheers! Happy wine storing!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    could pegs be added so you don't need to take out every bottle every time you want a bottle on the bottom cause right now you need to stack them In the order you're going to drink them otherwise it's just an annoying inconvenience to constantly be taking bottles out and putting them back in just for a bottom bottle.
    There is a solution to this. While it is true that you'd have to shuffle some bottles around if you are trying to grab the bottom bottle in the top or side partitions, if you put all your unique bottles in the bottom partition, these can be accessed more easily.
    In the bottom partition, approx 4 bottles are laying side by side, with 1-2 bottles laying on top (assuming you have it packed to capacity). You can either take the 1-2 bottles above them out before grabbing a bottle underneath, or just carefully slide the bottle you want out and let the other bottles roll in to take its place.
    While adding more partitions would remove this concern entirely, you'd lose some flexibility since wine bottles come in varying sizes and shapes. I hope this helps! Cheers!
    Thanks! I like the way the cherry stain turned out.
