How to Make a 30w Mega Flashlight
1,896
17
4
Published
Introduction: How to Make a 30w Mega Flashlight
Hi,In this intructable I show how to make 30w mega flashlight
Step 1: Led and Heatsink
first we need a 30w smd led chip and a heatsink.I mount led on the heatsink with screws.and don't forget to add some thermal paste.
Step 2: Adding Fan
I add a fan for more cooling it works good.
Step 3: Making the Box
I maked a box with hardboard for the led.
Step 4: Adding Switch and Female Connector.
added a normal on/off switch and a female power connector for charging the battery.
Step 5: Mounting the Led Into Box
mounted the led into box with screws.
Step 6: Bushes and Screws
Need 4 rubber bushes and 4 screws for base.
Step 7: Drilling the Hole
drill hole in the centre for screws.
Step 8:
mounted the rubber bushes
Step 9: The Battery Pack
Step 10:
mounting battery with double side tape.
Step 11:
Adding a metal sheet for xtra strong.
Step 12: Battery Charger
Iam using a automatic charger with thermal protection.It's output voltage is 12v.so that we can charge 11.1v battery.
Step 13:
Wiring the battery charger and battery.
Step 14:
This is a diy battery level indicator.The ic I used is 3914.If anyone want the circuit diagram comment below I will give you.
Step 15:
final wiring.
Step 16:
make a metal clamp for more strong.
Step 17:
close the top cover and glue it using hot glue.I added a on/off switch and a push on switch.
Step 18: Painting
painting using sparypaint iam using black.
Step 19: Final Look
I added a handle.
Step 20:
Battery level indicator at night
Step 21:
charging before the use charging voltage 230v ac
Step 22:
without led and with led
Step 23:
Without any light,with a regular torch and my mega flashlight.
Step 24:
regards,
Electro maker.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    2 Tips
    You can clearly see holes on both sides of the box
    ffs please tell me theirs a vent hole and its just not visable on the bottom or something... whats the point of a fan and no vent
    4 Comments
    I like this flashlight. I've got a torchiere lamp in my living room with about the same amount of power going to some LED's. Very bright.
    It's just my personal opinion, but I think you'd have a better chance in the Epilog IX challenge if you added to it. For instance, a complete list of parts and maybe even sources. Also, a circuit diagram and more detailed, step by step instructions. And, of course, schematics.
    Maybe I missed it, but I didn't see a device to limit current. Did you do a test to make sure that the current wasn't greater than the specified maximum allowed for the LED? If this is a 12 volt LED chip, then 30 watts would be around 2.5 amps.
    If I was making one of these, I'd want more protection for the LED. Maybe, if it could withstand the heat, a piece of polycarbonate sheet. Or a piece of tempered glass. Or maybe a wire cage, as you sometimes see on work lights.
    This led is only 1ampere and the cooling fan is about 0.5ah.
    You make the same error than many people wanting to drive a Led without current control and limit. Here, battery act as a current limiter, which means it produces heat internally and the Led is uselessly stressed. Apart from that, it's another 30W Led.
    I added a heatsink and a extra fan for the led
