How to Make a 3D Paper Origami Swan
914
11
6
Published
Introduction: How to Make a 3D Paper Origami Swan
About: I just enjoy doing crafts and entering contests :)
SUPPLIES
-Lots of paper (5-10 sheets)
-Paper guillotine (optional, it makes it easier to cut the pieces)
-Scissors (if you don't have a paper guillotine)
-Orange marker or highlighter
-Black marker (or 2 small black paper dots)
Step 1: MAKE PIECES
following the images, make a large batch of 3D origami pieces (you may need to make more later) when you cut the paper into the pieces, you can either cut them into either 16 or 32 squares (16 will make the sculpture bigger, as 32 will make it smaller)
Step 2: SWAN BASE
Starting with 7 double pieces (2 pieces placed on each other in this shape \|/) then make a tower 7,7,6,5,4,3,2 (the double pieces are all placed on the left side) repeat this 4 times
Step 3: CONNECT BASE INTO CIRCLE
As shown in the picture, connect your pieces into a circle
Step 4: MAKE a BOTTOM
as shown, place your base upside down and put the pieces in as shown to make a bottom
Step 5: MAKE THE TAIL
To make the tail make a tower 4, 3, 2, 1 then connect it as shown
Step 6: MAKE THE WINGS
For the wings, use double pieces (these ones are two stacked directly on top of each other) and make a tower 9, 8, 7, 6, 5, 4, 3, 2, 1 repeat this twice and attach as shown
Step 7: MAKE THE NECK
For the neck, make a tower of 2, 2, 2, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1. after that, make a new piece and colour it orange then put two dots on it as shown
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
    6 Discussions
    gm280
    4 months ago
    Not sure where you learned how to make this, or if you even designed it up yourself, but that is an amazing feat to see. Very nice project.
    I didn't design it myself, its one of the most popular 3D origami projects :) thanks
    yes, you can use any size of paper you want, just be aware of the size that the squares end up being :)
