iImage Information
These instructions will show you how to make a 9-pin serial to Ethernet cable. Serial cables are used to control and configure devices with serial ports. When converting one end to Ethernet, the signal is able to travel farther. When devices are spread out over a large area or placed inconveniently, such as ceiling-mounted projectors, being able to control multiple devices from one spot saves time and money. Only patience is required to make these cables; no prior knowledge necessary. It will take around an hour to complete a cable. After a few practice cables, they can be made in 10 to 15 minutes. With the ability to control devices from a stationary spot, you don't have to worry about searching for a remote or physically pushing buttons on the device.
Required Parts and Tools
Digital Multimeter
Wire Crimpers (Optional)
1 - RJ-45 connector (Optional)
Wire Strippers
Electrical Tape
[1]9-Pin Serial Cable
[1]Ethernet Cable
[2]4-Wire Splice Connectors
Step 1Strip the Serial Cable
iImage Information
1) Cut the serial cable using the wire strippers, leaving a couple feet on the female end.
2) Using the strippers, remove roughly 2 inches of the cable covering on the cut end to expose the inner wires.
