3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Bass Pickup
This instructable will show you how to make a guitar pickup using neodymium magnets, a couple Popsicle sticks, and some wire. Total cost for this project will probably be less then $5 (depending on the materials you have available). The sound is surprisingly good and will serve you well. You can replace an existing pickup or add one to mix with your existing setup.
This instructable is specifically for bass, so there are four magnets required. For a guitar, obviously you will need six smaller ones. Also, it's good to have a bunch of extra magnets lying around as it will make the project go quicker.
Step 1Materials
Materials
Materials Needed:
  • A spool of insulated copper wire. Different gauges will produce different sounds, but you want something very thin.
  • Two Popsicle sticks. These can be new or used.
  • 8 neodymium magnets (2 for each string). These should be less then the width of the Popsicle stick. Again, different sizes will produce a different sound. You can see the rough size of what we used here.
  • Gorilla Glue
  • Some Wax/beeswax or potting epoxy
Notes
I used 42 gauge wire. You need to strip the ends before soldering them to your electronics. You can do this with your finger nail. If you dont have this around, it will raise the cost of your pickup by about $25.
The magnets I used were .32 or .37 in diameter and .2 tall.
A stronger magnet = hotter output and more high frequencies (better for guitar)
Note 2
You can do the same thing for a guitar, cept you will need 6 rod magnets.
85 comments
1-40 of 85next »
Mar 29, 2012. 6:09 PMbman85 says:
what do you do for the ground?
Mar 27, 2010. 8:43 AMicepick244 says:
Could you use another material other than wood (popsicle sticks) something like metal or plastic?
Mar 29, 2011. 7:33 PM1spartan95 says:
Yeah, you could, but I want an excuse for eating 2 fudgesicles
Mar 15, 2012. 7:59 PMFinchbyFinch says:
agreed on all accounts
Nov 25, 2011. 1:02 AMbassmonkey says:
HI! stupid question, do you just need the extra 1 foot of copper wire to solder to your controls? If not could you explain how to attach the other necessary wires? Thanks!
Aug 21, 2011. 10:20 PMhaysnail says:
i prefer to use hot glue gun.
Aug 21, 2011. 10:17 PMhaysnail says:
is it the ear-phone magnets?
Oct 30, 2010. 5:45 PMsvend says:
were the maganets exposed or is that the wood in the holes of the pickup cover?
Sep 17, 2010. 11:27 AMPedrojoca says:
Those are some mad bass skills :D
Feb 13, 2010. 7:44 PMartistecher says:
So, in the end you have removed  the magnets on the top?
Thanks
Jul 27, 2010. 3:28 AMfood is goo1 says:
The magnets on the to were just to hold the pairs in the centre in place while they were being glued, i.e. to stop them all just jumping out of place and sticking to one another.
Apr 9, 2010. 7:50 AMefabric says:
You have to make something to hold your pickup at the end of your drill. keep the wire roll far away. The wire won't twist or break  that way.  Press the button, it wraps-up nicely... and fast !
Oct 22, 2009. 7:11 AMMagnnus says:
Do I have to keep the rows perfectly parallel when I wrap the wire
Oct 5, 2009. 8:20 PMstukatz says:
what will happen if i use 34 guage wire at 5000 or 8000 turns , or do i need less turns ..................... thanks
Jul 23, 2008. 8:47 PMThe Stumph says:
Would if you criss cross the wire Would it effect the pick up?
Jul 23, 2008. 10:14 PMJonny Appleseed says:
my local radio shack has it theres also this place called lightning joes that carries all the supplise to make your own guitar- including wire all the way up to 52 guage wire for pickups
May 14, 2009. 6:15 AMFreudianLemur says:
52 is incredibly thin, the thinnest I've heard of anyone using was 44 (the higher the number, the thinner the wire).
Sep 19, 2009. 5:42 PMSparrow40k says:
WOW! That would sound mad, my local stores highest is only 32 gauge.
Aug 18, 2009. 10:59 AMqballcat says:
if it breaks you dont have to restart. just burn off the enamel off both ends and re-attach them with a inline splice and light to tea light so you can dip the splice in wax to seal it up
Aug 9, 2009. 4:25 PMmaxxxem says:
Did you use an entire spool when you made the pickup? 5000 to 8000 wraps? Are you sure, because I would and need 15,625 inches (1,302 ft) to wrap 1 pickup 5000 times for my 5 string. Just wondering
Aug 9, 2009. 4:46 PMmaxxxem says:
My bad My bad i mathed it wrong it would be double that 30 thoudsand inches like 10 dollars for a 6000 foot coil
Jul 3, 2009. 5:01 PMmthw_allen says:
What are the blue and white wires made of?
Nov 19, 2008. 7:21 AMdanthemanj1 says:
Would there be anything different you would have to do when you make a musicman bass pickup, or is it basically the same thing? Is there anything different you would have to do? Just curious, because I'm looking at buying a musicman style pickup and if I can make one, I would save myself a lot of money.
May 14, 2009. 6:12 AMFreudianLemur says:
Musicman pickups are humbuckers which means you'd have to wind 2 coils. Look up more info on making humbuckers to see what I'm talking about.
Mar 19, 2009. 8:58 PMgratewhitesmurf says:
You say that different gauges of wire and different sizes of magnets make different sounds. How is the sound effected? Thinner wires make the sound more... what? Larger magnets do what to the sound? Thank you much.
Apr 16, 2009. 4:29 PMMrCakes14 says:
It has to do with the resistance of the windings, primarily. Thicker wire (lower gauge) has a lower resistance than thinner wire (higher gauge), but using more windings will also increase the resistance. A higher output pickup has a higher DC resistance then a low-output pickup, and vice-versa. Also, stronger magnets lead to more high-frequency response. Lastly, the height and width of the coil(s) can affect the tone (taller coils are 'clearer' and have less bass...). Hope that helps.
Apr 5, 2009. 5:12 AMlegolaptop says:
Can I use hot glue instead of wax?
Apr 2, 2009. 3:15 PMjdeanthecool says:
Wow man pretty cool idea, You should totally sell em on eBay or something. Might make a pair just to test them out and use http://www.play-bass.com/online_bass_and_guitar_tuner.html to tune up cause I am tight and can't afford a tuner too haha.
Mar 23, 2009. 2:31 PMsgtstadanko says:
do you leave the four magnets on top? If so are the four magnets on the top glued down or just held down by other magnets?
Mar 18, 2009. 7:21 PMannrrr says:
Really awesome instructable. I admire your wire-winding patience, it inspires me. Please clarify something for me: Did you just use two magnets per string because of the size of what you had? If you had a taller cylinder magnet do you think that would be cool? (PS, sorry for the double comment, I share this computer.)
Feb 21, 2009. 8:58 AMExtremofile says:
I'm tempted to give it a try, but i'll use neodymium magnets like these pups have:http://www.q-tuner.com
Dec 20, 2008. 8:53 PMSgtraccoon says:
Does the shape of the magnet have any effect on anything? Or, in other words, do the magnets have to be round or would I be able to effectively use square or block magnets.
Dec 18, 2008. 9:41 AM8bit says:
How was the tone in the new pickup different than the old one?
Dec 6, 2008. 4:34 PMRussianGun says:
Hey nice instructables but i dont see the tops of the magnets in the pic do i put it on with the magnets facing down??
Nov 4, 2008. 12:03 PMjchot says:
where is the cheapest place to get said magnet-wire? I haven't seen any for 25$.... hey laminterious, where did you get yours?
1-40 of 85next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:laminterious
