Introduction: How to Make a Bath Bomb
Picture of How to Make a Bath Bomb
This instruction set will guide you through each step of making DIY bath bombs!
Step 1: Gather Your Ingredients
Picture of Gather Your Ingredients
In order to make your bath bombs you will need to use:
  • 1 cup Baking Soda
  • 1/2 cup Citric Acid
  • 1/2 cup Epsom Salt
  • 1/2 cup Corn Starch
  • 2 1/2 tablespoons Almond Oil
  • 3/4 tablespoons Water
  • 2 teaspoons Essential Oils (optional)
  • Liquid food coloring (optional)
  • Mixing bowls
  • Mixing spoons
  • Mold (Silicone, Plastic, or Stainless Steel)
Step 2: Combine Dry Ingredients
Picture of Combine Dry Ingredients
Combine and mix 1 cup of baking soda, 1/2 cup of corn starch, 1/2 cup of epsom salt, and 1/2 cup of citric acid in a large bowl.
Step 3: Combine Wet Ingredients
Picture of Combine Wet Ingredients
Combine and mix 2 1/2 tablespoons of almond oil, 3/4 tablespoons of water, and 2 teaspoons of essential oils (optional) in another bowl.
Step 4: Combine Wet and Dry Ingredients
Picture of Combine Wet and Dry Ingredients
Slowly pour your wet ingredients into your dry ingredients and mix together in a large bowl. TIP: If added too quickly, the mixture will be clumpy.
Step 5: Separate Mixtures Into Different Bowls
Picture of Separate Mixtures Into Different Bowls
Separate combined mixture into different bowls in order to create different colors.
Step 6: Add Food Coloring and Mix
Picture of Add Food Coloring and Mix
Add 4-5 drops of liquid food coloring to each bowl according to the bath bomb design you have chosen. Mix thoroughly. We chose to layer our bath bombs with purple, green, orange, and pink, therefore, we needed four mixing bowls.
TIP: Mixing the food coloring with your hands can be more effective than using a spoon.
Step 7: Mold Bath Bombs
Picture of Mold Bath Bombs
Pack mixture tightly into mold once you have achieved desired color. You can make your bath bomb a single color or stack your colors to create a colored pattern. For example, we layered our purple and pink by packing the pink mixture in tightly half way through the mold, then packed the purple mixture tightly on top.
You can use either silicone, plastic, or stainless steel molds.
Step 8: Remove From Mold
Picture of Remove From Mold
Remove bath bomb from mold and place on parchment paper. The Bath Bombs typically dry after about 15 minutes.
TIP: Make sure the bath bomb is dry before you remove from mold, otherwise it will crumble.
Step 9: Let Dry 24 Hours
Picture of Let Dry 24 Hours
Place bath bombs to the side and allow to dry 24 hours before using.
TIP: If mixture begins to rise (the bath bomb will look puffy), then place the mold in freezer.
Step 10: Place in Bath and Enjoy!
Picture of Place in Bath and Enjoy!
Once completely dry, your bath bombs are ready to be used! This recipe will yield 4-6 bath bombs. Soak in bath for 20 minutes!
dlevenson (author)2016-06-21
Also, make sure to stir all dry ingredients extremely well or you will get "warts" on your fizzies. Happy fizzing!
Nice instructable. The foaming is caused by the reaction of the water with the citric acid and is taking away from the foaming you will get in the bath. You can use 91% rubbing alcohol, vodka, or witch hazel in place of the water and add your liquids with a spray bottle while stirring to cut down on the foaming. Add your essential oils directly to the dry liquids and as long as they are pure (without water) they won't foam.
wold630 (author)2016-06-17
This is really fun! How long to they take to dissolve in water?
Engl2311ECJ (author)wold6302016-06-17
Not long at all! About 2 minutes to dissolve completely in the tub. :)
About This Instructable
2,518views
85favorites
License:
More by Engl2311ECJ:How To Make A Bath Bomb
Add instructable to:
