3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Big Batch of Kombucha
Step 17Decant Over-Fizzed K'cha
Decant Over-Fizzed K\
The bottles will keep fermenting and carbonating until something stops them.
That could be running out of sugar, building up too much alcohol, acetic acid, lactic acid, or exploding.
This is why store-bought kombucha can never be as good as stuff you make yourself. They'd get sued when a forgotten bottle blew up and hurt someone. So they have to make it sour and not sweet. That way fermentation terminates or gets very slow and they can even put it in glass bottles.
I've seen plastic bottles of home brew k'cha puffed up round with no necks or puckers on the bottom. They ring like a bell if you tap them, and it's scary dangerous. Use bomb squad methods to deal with bottles like that. Three of mine once went off in a daisy-chain. They blew the side out of a rubbermaid bin and put dripping splatters all over the ceiling. Bottles like this could cripple, deafen, or blind you.
A more common problem ( opportunity ) is bottles with so much fizz it's hard to open them without champagning k'cha all over the room instead of into a glass.
Here's one way to deal with that. First refrigerate it. Gas solubility is higher in cold water.
Then rapidly open and pour the kombucha into an angled glass. The angled glass and angled bottle present a much larger area surface for the gas to diffuse out. If you set the same bottle vertical, the upper surface is too small and you can get a volcano effect.
If your stuff has too much fizz even for that, we're in the realm of art, devise your own methods.
Freezing is bad. Ice has poor gas solubility and plugs the neck when you open.
Some people like to barely open the cap so a slow hiss of air comes out, too slow for bubbles to erupt. I like to open the cap and instantly squish out the remaining air before the eruption. It's amazing how the bottle re-inflates every time you do that. There can be a huge quantity of gas dissolved in the liquid.
Enjoy your super-delicious fizzy healthy K'cha!
3 comments
Sep 3, 2010. 8:55 PMTahoeGal says:
To add to "Chard"'s comments about adding sugar to the bottle to increase fizz... Intead of sugar I thought I would compliment the natural apple essense of KT by adding unfiltered bottled apple cider when I bottle.I have been having really good results adding about an inch to a 16 oz glass bottle and leaving about an inch of head-space and then put the bottles back in the "incubator" at 75 F for 4 days or so (no explosions-the re-used plastic lids did expand a bit.) Also, a mix of the cider and a small amount of ginger juice with the bits from pressing through a garlic press (a little goes a long way). I love both these flavors ...sparkling apple cider and the ginger/apple cider. I think the ginger/apple mix is especially good if you have a cold or during colder months. I was nervous about using a non-pasturized juice because of mold/contamination/etc (the bottled cider is pasturized) but I went ahead and made fresh mango juice/puree and added an inch of that to the bottling. All I can say is wow on the fizz! It was a very tasty batch, if very hard to get into the glass! I would have to guess that the alcohol content is higher since the raw juice will ferment, but not real sure. I took samples of the Mango to my local health food store and they swore it tasted just like GT's Mango KT. My next trial is going to be with fresh peach juice/puree because they are on sale this week at Safeway for 49 cents a pound! So, there you have it. My fizzy flavor taste trials ;D Contact me with what you have been trying! Christine Peace and Love!
Jan 16, 2012. 8:58 AMChanio says:
Good perception with the blendings!
I would try adding some STEVIA leaves to the bottle as a sugar substitute that would increase the fizz.. Stevia leaves are good because, though not as sweet as sugar work well as a natural substitute and helps diabetic persons with their illness.
I noticed that when preparing any sweet fruit juice with water and stevia leaves, after bottling it and keeping it for a week, it starts fermenting and becoming alcoholic. As if stevia would be eating the sugar of the fruit and transforming it into alcohol...
I must try kombucha!
THXs!
Alberto
Jan 17, 2012. 5:44 AMjhanger says:
I'm not sure you would be able to use stevia. The sweetness from stevia doesn't come from sugar, but from something else.. Unless it's a carbohydrate of the sugar strain it won't ferment. Starches as an example are a carbohydrate but won't ferment without being broken down into sugars ..
While it's a great idea, i don't think stevia would be an adequate fermenter for adding fizz... sweetness yes, fizz no...
Though it can't hurt to try and prove me wrong ;)
Sep 8, 2009. 11:30 AMjjbarnwell#2 says:
I have been brewing kambucha tea but I can not get mine fizzy most of the time. Every once in a while but for the most part its flat, and I like the fizz what do I do?
Sep 29, 2009. 12:14 PMChard says:
ok i have never made this before (im planning to when i have finished a few other projects) but i know a bit about brewing. the likely reason for the no fizz is that your leaving it in its 1st stage of fermentation for too long and all the sugars are used up. this means that when you put it in bottles theres no sugar to turn into CO2 (and alcohol). its the same with brewing beer. 2 ways to avoid this are to bottle it a few days earlier than usual so theres still some sugar left or you can add more sugar before bottling. this second method is called 'charging' in homebrew speak and all you do is add 1/2 to 1 tsp of sugar per pint or so of liquid into the bottle before you pour in the liquid. then give it a swirl to mix it in and seal up the bottle. hope this helps / works
Apr 20, 2009. 1:03 AMmeowzebub says:
Howdy Tim - love the detail & commentary. by far the best kombucha instructable. especially appreciate the "play-by-play" of k'cha development. thanks! my 1st batch is in the closet; bubbly, but still smells like sugar. thanks to you, I know that is just right!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
