How to Make a Bottle-Cap Whistle
3,892
82
6
Posted
Introduction: How to Make a Bottle-Cap Whistle
If you find yourself at a party this summer do not let those pop cans and bottle tops go to waste.
Requirements:
Bottle caps
Empty pop cans
Tin snips or good scissors
Hot glue gun
Step 1: Cutting the Pieces
You will need to grab that pop can and cut the bottom and top off so you are left with a sheet of tin foil.
Step 2: Cutting the Inner Part of the Whistle
For the second step you will want to cut 2 pieces from the foil.
on one cut will be going long way with the can the cut should be about as wide as the tab from the pop can
the other cut will be a box about the size of two tabs from the pop can.
Step 3: Making the Inner Part of the Whistle
Fold the wide piece of foil around the long narrow cut and cut the corners of the top.
Fold the top of the long end down and over the fold to hold the wide piece in place.
Step 4: Making the Shape
Fold the long piece around and through the top.
Step 5: Making the Shell
Cut a slit in both bottle tops that are the same size.
Step 6: Hold Them and Fold Them
Take the folded pop can and but on the inside and glue it down with hot glue.
Step 7: Slice and Dice
Cut a slit on the top before putting the other bottle top on.
Step 8: Tag Them and Bag Them You're Done!
To finish hot glue the other bottle top on let it dry and get your blow on!
  • Used wood glue as a ...-narrowyoureyes
    narrowyoureyes made it!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
5 Comments
when you say just a sheet of tin foil, could you use tin foil that you buy from the store as well? or is there a difference? thanks! this looks like a must do project!!
you need a stiff,rugged yet flexible piece of tin. That's why soda cans work well for this. On the other hand, if you look at professional whistles you'll see they use a thicker piece of metal that are either soldered or glued together.
okay. thanks. are the edges of the soda can sharp?
Very cool! Thanks for sharing!
