How to Make a Burlap Wreath
6,960
40
Posted
Introduction: How to Make a Burlap Wreath
Items Needed:
1. Burlap cloth or strips (at least two yards (1.8 meters) of cloth or 24 feet (7.3 meters) of 8-inch (20 cm) wide garland)
2. Wire wreath frame of any size
3. Embellishments of your choice
Step 1: Cut Burlap Into Strips
If you buy cloth burlap, you will need to cut it into 8 inch-wide strips. Otherwise, the garland is already the right size.
Step 2: Roll or Gather the End of a Burlap Strip
Weave it through the wires of the wreath base to start. This serves to hold the end in place while you assemble the rest of the wreath.
Step 3: Pull a Loop of Burlap Through the Wreath Slats
Step 4: Lift the Loop
Fluff it out to the size you want the wreath to be. This is generally a 2-3 inch (5-7.5cm) high loop.
Step 5: Pull Another Loop Through the Next Slat Over
Repeat back and forth until you completely hide the wire frame. This can be done with as little as 12 ft (3.6 meters) of burlap strip or as much as 36 ft (11 meters), depending on how thick and full you want your wreath to be. The wreath shown used two yards (1.8 meters) of burlap, cut into 8-inch strips.
Step 6: Slide the Loops Firmly Together
This will make space on the frame for more loops and "puff out" the wreath some more.
Step 7: Adjust the Loops to Make Your Wreath Look Even
Step 8: Decorate the Wreath With Seasonal Items
You can reuse the base many times so long as you avoid gluing anything to it. Instead, use decorations you can wrap around or wire to the frame so that you can easily replace them from season to season.
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    This gives a very interesting texture! I like it a lot!
