How to Make a Candle Wick
Published
Introduction: How to Make a Candle Wick
Did you know that you can make a candle wick out of household items? In this Instructable I will demonstrate how to make a candle wick out of common household supplies.
Step 1: Supplys
-scissors
-wax
-pliers
-cotton string
Step 2: Melting the Wax
First, cut the string to size. Then, melt the wax and soak the string in it. Finally, take out the string with the pliers and let the wick cool off.
Step 3: Finshed
Once the string has cooled off, you can put it to use in a candle.
  • Backpack Challenge
    Backpack Challenge
  • Stick It! Contest
    Stick It! Contest
  • BBQ Showdown Challenge
46 Discussions
U can use crayons.
Melt them in a sauce pan and Presto!!!!
U R Done
Make sure that the crayons are non-toxic though, usually it is printed on the label of the pack or on the crayon itself.
You can recycle bacon grease into candles. Strain your used grease (while warm in liquid form) through a paper towel placed in a rice strainer into a pan. Add some wax (you can use the remnants of used candles, ideally unscented to retrain the bacon smell) and heat on low stirring gently until the bacon grease and was combines. Pour this mixture into a recycled container (pickle jar, can, or any metal/glass container) and then insert your wick. Lay a pencil or chopstick across the opening of the container and tie the wick to it. This will keep the wick straight while the wax/grease solidifies. Once it's solid untie the wick (carefully without pulling it out of the candle) and cut it to an ideal length. The wicks described in this instructable would work great in this application.
just buy a candle and use the left over wax from it
Does anyone have any tips for senting candles? All I have is pepermint and I don't know how that would smell with crayons.
Anything oild based I use Wilton treatology. They smell amazing my favorite sent is warm cinnamon graham
essential oils...either bought or homemead...can be made with herb of your choice steeped in extra virgin olive oil (preferably extra virgin) for three days then strain thru pantyhose or cheesecloth and there is your essential oil! add to your wax when it is melted right before you set your candles...scented! enjoy!
If I were you I would, take any of your essential oils. Or you can melt your fruit smell or something like in pot. This is what I did I used strawberries. First I put the strawberries in a pot then I had them sizzling for about 2 minutes then I put the wax in and mixed it in. Put it in the glass cup or whatever you are using to for the candle. I took some mod modge painted it on the sides of the cup and put up sprinkles in the bottom and put my hand over the top the cup and shook the cup around till there was so ankles over all of the sides of the cup. And let it dry first though. Hopefully this will answer your question
Lighter went out... was still too drunk to be wandering around public... So i came across this article trying to make a candle so i didn't have to get up and light a marlboro off the stove... The string i had wasn't cotton... like mylar or some petroleum based string i bought to run trot lines when fishing... that did not work as a candle wick... so i seen a napkin lying there and a spool of sewing thread... rolled up the napkin tight, but i left like a 1/8th inch thickness to it. Wrapped that in sewing thread. it did turn my white candle wax black. but i was able to secure my homemade wick at the bottom of the candle i was using... the wick was too thin and it burned the center down out of the candle... after i attached my wick, i melted some wax i cut off the candle cylinder i was working with until everything was level. trimmed my homemade wick and yeah it works. it don't smell the best... but it did light a marlboro. and it didn't burn up fast like the thin wick that came with the candle when i bought it. Thanks for the iDIYa. got me out of a pinch.
If your lighter went out, how did you light the wick, just asking just incase my lighter ever goes out lol?
a little trick i learned in prison. take a empty BIC lighter. hold it sideways at SLIGHT downward angle. GENTLY roll the wheel but DON'T spark it. the goal is to get a small pile of flint powder to accumulate in the side of the metal guard that wraps around the front of the lighter. once enough powdered flint is gathered, you can then spark it and it will flame for a few seconds. I never throw away lighters. Never know when you'll need one. also theres a tattoo needle and guide inside a BIC also.
Wait- How did you light the your new candle wick?
queer1
1 year ago
I've been making all kinds of candles from leftover candle wax anc crayons for years. My problem has always been making my own wicks. So far the best materials I found to make my wicks with was been hemp twine however depending on how well you soak the twine it can end up burning too hot resulting in the wick ending up drowning. Recently I found another solution which I like a lot. I had a lot of canvas scraps from a sewing project so I cut it into long very thin strips and followed my usual soaking process. They work really well especially if the wax I soak them in is paraffin wax regardless of what kind of wax the candle I use it in is.
Tudah Rbah (thank you very much). The real Name of the Creator is Yah (short version); Yahuah (modern version); Hayah (ancient version that I use, since I do not use the changes added by mankind). Halaluyah means highest praise to Yah. Do the 7 appointed times as written of in Leviticus 23 (but no more animal sacrifices).
hi there
Does anyone know how to purchase the right thickness candle wax...for the different size candles?
