3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cardboard Puppet Stage
Here's how you can make a puppet stage in a day.
Its lightweight, strong and portable and looks great for a hand puppet performance.
Includes new tips you can use to make hinge cupboards out of leather and balsa wood / thick cardboard.
Here's how to make the puppets displayed in this instructable: http://www.instructables.com/id/How-to-Design-Hand-Puppets/
Check out more a sample from Eric Guiomar's book step by step
New! Eric Guiomar's new pdf book part 2 is available.  Also excerpts of first book How to Make a Ming Table free download here:
Chapter contents
Part A & B French Instructiions for Ming Table
Scroll down to
Extraits du livre
  • Table des matières - Fichier PDF (404.5 Ko)
  • Tabouret Ming (pages 12 à 15) - Fichier PDF (1.3 Mo)
  • Tabouret Ming (pages 22, 23) - Fichier PDF (1.1 Mo)
Check out many French Cartonnistes Websites below:
Check out ways you can use puppetry for educational purposes:
http://www.nostrings.org.uk/
http://www.youtube.com/user/nostringspuppets
Step 1Measure and cut
Measure and cut
1. Draw the front side by tracing a rectangle onto 2 or 3 ply cardboard.
2. Check the direction of the cardboard, it should be vertical for stronger structure. (If cut on the vertical, it will bend easily)
3. Glue struts to front and back frame. I tried cold glue, but hot glue seems to work best.
10 comments
Aug 31, 2008. 6:26 PMSunny124613 says:
i like the color of the stage and i also love your puppets!!!
Sep 1, 2008. 7:38 AMSunny124613 says:
oh no,I am only talented with the working of puppets not the making of puppets
Sep 2, 2008. 2:08 PMSunny124613 says:
I dont write my story scripts but I do a class and all of the puppets sing the songs like Under The Sea and we do black light (you know like glow in the dark!)and it is really cool in the end
Sep 2, 2008. 5:03 PMSunny124613 says:
well,you can buy glow i the dark fabric,but we use a black light spray or paint that you can get if you look it up,you don't need to use fluro fabrics(and I suggest you don't because of wear and tear around the mouth,we use this type of foam,but I don't know what it is called),the light is called black light and even though it is blue,it makes anything with black light spray or paint glow!and this is not me but it is something like this.(to find a puppet store near you just use Google)
  • tip:if you stay with the puppet store for a long time,you sometimes can get discounts,only if it is not a mean old lady,try to get the younger foolish ones to give you puppets at a discount price and usually if you bribe them with like,5 bucks more with the discount price they will let you buy it.
I hope this paragraph helps!!!
Sep 3, 2008. 4:51 AMSunny124613 says:
ur welcome,all I want to do is help
Jul 18, 2008. 2:08 PMcaitlinsdad says:
Nice. I see you could have fancied it up by cutting the top out with scrollwork or cut it in a shape of a castle for fairy-tale theater. I like to work with cardboard too but I prefer the non-toxic glues. The woodworking glues have a better tack and still relatively cheap when you use so much to laminate the cardboard. I also peel the paper from scraps to use as my "gummed tape". Recycle as much as I can. Please put up an instructable on those puppets if you made them!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
91
Author:Scriptone
