iImage Information
Feel like real BBQ? Don't have a smoker? Don't feel like spending more than 10 bucks or so? Like Alton Brown? Here's how to make a very serviceable smoker out of a cardboard box and some other things you might have laying around the house.
This rig worked remarkably well. The biggest problem was getting the temperature high enough. You want to cook BBQ at around 225 degrees F. If you can't get your smoker up that high, you can still use it to smoke, then finish whatever you're cooking in the oven.
Step 1Get a cardboard box
iImage Information
You need a box that's big. But not too big or you'll never be able to heat it up. My box is about 4 feet high, and two feed square. This is actually on the larger end of the size you want. Cut a hole in the bottom as shown, so that you can change the wood chips out during the cooking. Its a lot easier if you leave the bottom attached to use as a hinge.
I did this, but had a failure of my drip pan, putting all of the drippings into the hot iron pot. This was fine until I opened the top to get the meat out. As soon as oxygen got into the bottom of the box, instant greasefire in a cardboard box.
I Strongly suggest that you open the box by first opening the heat access hatch and removing the iron pot so that if it does flare, it does so safely away from flammables.
http://cooking.meetup.com/532/calendar/9720800/
