3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Case for Your DS Lite Games
I wanted a case for all my games to keep in the house, so I could store their plastic boxes out-of-sight, but all the cases I found online would only hold 8. This isn't meant for travel, since it holds so many games. However, you can alter everything about this pattern; making it smaller, adding handles, adding ties instead of Velcro, or making it more folio-styled with a zip, etc.
I used leftover fabric from a pair of trousers, and I ransacked an old pencil case for the plastic. I didn't use exact measurements. I did most of it by eye, so it's a bit wonky, but the potential for making something really professional-looking is there, if you take more care than I did. It was also my first project of this nature. I only things I've ever made before is a pair of curtains, and a cosmetic case with a zip.
What you need:
~ very basic sewing skills
~ a sewing machine
~ standard sewing notions, like thread, scissors, pins, etc.
~ fabric, the amount dependant on size of project.
~ bias tape or fabric for the edges, or anything to decorate it.
~ plastic for the games slots, if you want, but can use fabric.
~ Depending on size, detail, and skill, about 6 hours/weekend?
~ a presser foot that will work with plastic
~ patience!
Step 1Getting Started
Getting Started
I want to mention that I used a 'button foot' on my machine, because when I first tried to sew the plastic on, it kept sticking to the foot and wouldn't move. I'm not sure if I was just doing something wrong with the standard foot or what, so I switched to the only other foot I had on hand. It worked fairly well, but there's a trick to using it; because the foot is about 2 inches long and slides , you have to start sewing with the length of the foot in front of the needle. As you sew, it slowly starts moving towards the needle, but then the needle runs out of room and gets stuck, so before that happens, with the needle in the fabric (down), lift the presser foot lever, and push the sliding bit back to the front. It's annoying, but more skilled people might know a better way. I really don't know much about sewing. An alternative to such a time-consuming process would be to use fabric and a standard foot.
So to start: Plan your project.
How many games do you want it to hold?
What style?
What colors do you want to use?
Things to help improve the overall look:
~ use a cutting matt with a rotary cutter
~ pre-wash your fabric and iron it.
~ Slow and steady, especially when sewing those seams.
~ If you mess up and sew a wonky seam, tear it out with a seam ripper and do it over. I messed up quite badly, and re-did it. It was worth the effort!
For the project here, you need two pieces of fabric, whatever size you like, as long as the pieces are identical in size. Figure out how many rows you want, and how many games on each row. As you can see from mine, it's quite large... When closed, it's 23cm wide x 9cm long x 4cm deep. If you want it more travel-sized, make it smaller.
If you want it more substantial, you can add a lining; padding for quilts or foam maybe? I used bits of an old pencil case that had slight padding so I added this, as you will see later, but it's optional. If you choose a thick fabric (like upholstery fabric, denim, etc.), that should be enough protection anyway.
So have the fabric cut to size. Then cut your plastic. If you're using fabric, then I would use a piece with edges folded in (width-ways) and even maybe use the iron-hemming stuff to seal it (iron-hemming stuff: I think it's called fusible tape and you put it between two pieces of fabric, or a folded piece, then iron it, then the tape melts, hence you've magically hemmed the material). If using plastic, cut to exact size needed, no folding.
If the fabric has two sides (a nice and a bad one), lay one piece of fabric with the nice side up. Then lay out your cut pieces of plastic/fabric onto the fabric, placing it where you want it. Use pins to secure it, keeping in mind to pin it perpendicularly to the way you're sewing, so you don't break your needle or so the pin into the fabric!
Get ready to sew!
1. Sew the lengths, then the sides. An easy way to do this without cutting in between each different rectangle, is to sew, then when you reach the end, just move the needle and sew again, When you're done, then you can cut each thread in between. Mind you, I used a triple stitch, which is stronger, so if you're only using a single stitch, you might want to reverse-stitch at the end of each rectangle (to keep the thread from ripping out if someone yanked on the plastic). Note: I also used the 'stretch/elastic' setting, because the corduroy and plastic kept bunching. Experiment and see what works best for you.
2. I also sewed on the velcro, top and bottom
37 comments
Aug 16, 2009. 7:14 AMD.L.H. says:
This is very unique
Sep 15, 2010. 3:20 PMloit says:
yeah this was a great idea i made it already is so cool thanks for posting!- 11 years old, anna
Nov 22, 2009. 5:02 PMMcKayla2013 says:
WOW great tips i googled how to make one and it wouldnt show me the results and my friend told me about this i used just black and white fabric with bright color ends for the tips i got some iron patches and made my name and did the deco that way it looks awesome
thanks
May 15, 2009. 2:07 PMAtomman says:
Cool! Kinda odd shape, I would use all black fabric and make it smaller.
Mar 15, 2009. 5:42 PMBurningBlades says:
This is a pretty cool idea, and I'll probably make one once I can find some good plastic to use. One thing I'd add to it would be a pouch for stylus's (styli?), because if your DS is anything like mine, the designated stylus hole has kind of worn down and there's no friction to just keep the stylus from falling out.
Dec 27, 2008. 8:40 PMsewer27 says:
I think this looks awesome. I have a sewing machine but it is currently broken. So I will make one tomorrow but try just sewing by hand. If that doesn't work I'll just wait until my sewing machine is fixed! Thanks for the great instructions!!!!
Apr 5, 2008. 10:44 PMCoolJB says:
If I did have the materials,I would make one of these. =P
Dec 22, 2008. 7:02 PMlowtherand says:
pence, you live in England don't you. for those who dont kjnow a pence is roughly 2 cents.
Aug 9, 2007. 12:57 PMedrainkona says:
This also works with regular DS Games, FTW. (They're the same size.)
Aug 10, 2007. 2:07 AMcraig3 says:
I dont understand why everybody calls it a DS lite by default, its just a Ds or nintendo DS. I have the original DS in blue and im never going to change it for a lite
Sep 11, 2008. 1:45 AMemygirl797 says:
well, by my standards, the ds lite is much better. as told by the "lite" portion of the name, it has a brighter backlight, making it much easier to see whatever game you are playing. I love interacting between games, and I have a ds lite, but I am saving up so I can trade in my crappy regular ds for another lite. my original ds is also in blue. it sucks. however, this is simply an opinion, but I felt the need to explain to you what the difference between the two are. also, very good tutorial, I made a pillow in home ec back in school, and I have basic sewing skills, so this project will be awesome! thanks a lot!
Nov 4, 2008. 5:13 PMmettaurlover says:
The lite is smaller and brighter, but the DS has more reliable slots. my lite works about 1/5 of the time, while my DS works about 4/5 of the time. it's not worth it to buy a lite, unless you don't have a DS, which they have stopped selling.
Nov 4, 2008. 5:11 PMmettaurlover says:
1) THEY ARE NOT DS LITE GAMES! they are just plain DS games. they'll work on both versions. 2) there are about fifty EASIER ways to do this, and most of them are cheaper and more efficient.
Apr 5, 2008. 7:14 AMsmeata says:
looks cool. or as cool as anything sewn can look lol. im gonna make one tomorrow when im sober. but i think mine wont need as many game slots, you cant have that many games?
Sep 16, 2008. 6:27 PMbeauwalker23 says:
looks great!
May 31, 2008. 5:30 PMDoctor What says:
Very nice. I don't have quite that many games to make another case, but when I do...
May 18, 2008. 5:48 PMiLikeCoolStuf says:
yes it will be useful if I have a nintendo ds
May 10, 2008. 8:42 PMCMKJubilee says:
On the whole "homebrew" debate, I see it like this: You buy your own game, then copy it as a backup. If you break the first one, you'll have another one as if it never happened.
May 10, 2008. 11:57 AMCMKJubilee says:
Hey, I'm gonna try this for my UMDs. Kudos, and Thanks a bunch!! I've been looking for a way to make my own!
Apr 6, 2008. 7:12 AMGizmo_gal says:
I'm going to make a case for my Handhelds plus games, but this one is a little to much for me. I cant really use a sewing machine (I actually sewed my hand to the fabric and my sister got me loose by using manicure scissors and slowly pulling the thread out slowly. All the way up side of my hand and pinky. after that my mom banned me from using it. I tried again a few times later but I nearly did the same thing. I think I need something simpler or something I could sew by hand.)
Mar 21, 2008. 3:35 PMkitty_lld says:
kool i made one i think that this pics is kool!!!!
Apr 3, 2008. 10:48 AMsmb127 says:
Love it love it love it. I was trying to figure out what to do with all the games now I know. I am going to get my DD to make one for her and her brother. Thanks.
Feb 19, 2008. 6:26 PMtyler_rocks says:
very nice looks pretty good
Dec 1, 2007. 11:48 AMKaitlinthegreat says:
Very nice,too bad I have terrible sewing skills and don't know how to rethread my basically toy sewing machine.
Aug 24, 2007. 9:18 PMOneGirlCircus says:
I think this is great! My son is starting to be interested in sewing, and this is just the project to spark his imagination! Thanks for sharing. Oh, also a tip: for sewing on anything sticky like plastic, use a teflon foot (or "glide" foot) for your sewing machine. Or, you can insert some tissue paper between the plastic and the foot, but that's a little cumbersome and not entirely predictable. Your buttonfoot use was very creative.
Sep 29, 2007. 3:03 PMlordwilliam says:
nice very nice i might make one of these i have some GGA/ds cardtige cases and they are rubbish you acctually need a GBA cartirage to use em and stop the ds things fallin out
Aug 16, 2007. 9:07 AMg12345389 says:
i see pokemon pearl
Aug 17, 2007. 11:28 AMJ_SCAP says:
i see a rare Japanese wario ware with yellow insted of orange logo sticker how much you want for it
Aug 19, 2007. 6:36 AMg12345389 says:
2nd on top?
Aug 16, 2007. 12:12 AMTvman says:
(removed by author or community request)
Aug 10, 2007. 2:46 AMjonosf says:
Looks like ya need to get some more games to fill it up! Similar to what some friends made for all my knitting needles. Another project to add to my never ending list! ciao
Aug 9, 2007. 4:37 PMTangMu says:
This is great, am definately going to try this when i get hold of a sewing machine.
Aug 9, 2007. 12:55 PMnepheron says:
cool idea
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:xrissy(www.christinacary.co.uk)
I'm an American Singer-songwriter/Composer living in England... I adore all things crafty. If it's creative, I'll try it.
