Step 1Getting Started
So to start: Plan your project.
How many games do you want it to hold?
What style?
What colors do you want to use?
Things to help improve the overall look:
~ use a cutting matt with a rotary cutter
~ pre-wash your fabric and iron it.
~ Slow and steady, especially when sewing those seams.
~ If you mess up and sew a wonky seam, tear it out with a seam ripper and do it over. I messed up quite badly, and re-did it. It was worth the effort!
For the project here, you need two pieces of fabric, whatever size you like, as long as the pieces are identical in size. Figure out how many rows you want, and how many games on each row. As you can see from mine, it's quite large... When closed, it's 23cm wide x 9cm long x 4cm deep. If you want it more travel-sized, make it smaller.
If you want it more substantial, you can add a lining; padding for quilts or foam maybe? I used bits of an old pencil case that had slight padding so I added this, as you will see later, but it's optional. If you choose a thick fabric (like upholstery fabric, denim, etc.), that should be enough protection anyway.
So have the fabric cut to size. Then cut your plastic. If you're using fabric, then I would use a piece with edges folded in (width-ways) and even maybe use the iron-hemming stuff to seal it (iron-hemming stuff: I think it's called fusible tape and you put it between two pieces of fabric, or a folded piece, then iron it, then the tape melts, hence you've magically hemmed the material). If using plastic, cut to exact size needed, no folding.
If the fabric has two sides (a nice and a bad one), lay one piece of fabric with the nice side up. Then lay out your cut pieces of plastic/fabric onto the fabric, placing it where you want it. Use pins to secure it, keeping in mind to pin it perpendicularly to the way you're sewing, so you don't break your needle or so the pin into the fabric!
Get ready to sew!
1. Sew the lengths, then the sides. An easy way to do this without cutting in between each different rectangle, is to sew, then when you reach the end, just move the needle and sew again, When you're done, then you can cut each thread in between. Mind you, I used a triple stitch, which is stronger, so if you're only using a single stitch, you might want to reverse-stitch at the end of each rectangle (to keep the thread from ripping out if someone yanked on the plastic). Note: I also used the 'stretch/elastic' setting, because the corduroy and plastic kept bunching. Experiment and see what works best for you.
2. I also sewed on the velcro, top and bottom
Add Comment
