3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Cheap Multitouch Pad
video How to Make a Cheap Multitouch Pad
ALL HARDWARE AND SOFTWARE UPDATES WILL BE MADE ON MY BLOG:
http://sethsandler.com/multitouch/mtmini/
What's a MTmini?
A Multitouch Mini, MTmini for short, is a cheap, small, portable multitouch pad. It can be used for all different purposes including: drawing, OS navigation, multitouch operation, games, entertainment, experimentation, and more. I created the Multitouch Mini to show people how something that seems complicated or 'magical' can be made simply and at low cost.
The MTmini uses the "Front Diffused Illumination" multitouch technique, with normal ambient light (infrared not required or needed) and a normal off-the-shelf webcam (IR filter can still be in place). The MTmini technique is the first step in creating a full multitouch display.
-Parts List-
  • Box (ie. Cardboard, Plastic, etc)
  • Piece of Clear, Flat Sturdy Material (ie. Glass, acrylic, plexiglas)
  • Paper (ie. printer paper, tracing paper, almost any paper)
  • Webcam (most web cameras will work)
  • Computer (dual core recommended, but not needed)
  • Optional Picture Frame
Total Cost: $5 - $50
-How's it Work and What Conditions are Necessary?-
When you place your fingers on the surface, shadows are created where your fingers are placed. The webcam sees these shadows and sends the image to the tracking software which tracks the shadows as they move on the touch surface (paper).
All you need is a room with (at least) some light; a dark room will not work. Even room lighting gives the best results. Lights shinning from multiple directions onto the multitouch pad gives better results than lights from one direction.
-More Informatio including Software, Applications and More At-
-Want to Build a Multitouch Surface?-
You can find information on how to make your own multitouch surface by viewing the How to Make a Multitouch Surface page.
192 comments
1-40 of 192next »
Apr 25, 2012. 6:47 PMarjay1491 says:
Hi uhm... how do i fix this problem? "missing msvcp71.dll" I made it work before but now I don't know what to do. Thanks.
Apr 25, 2012. 8:23 PMarjay1491 says:
ok that worked, now I have this "The application was unable to start correctly(0xc0150002). I already have my big box and all set, just the software is my problem.
Apr 22, 2012. 2:40 AMJerryBYong says:
Hi there! Quick question, do I need a IR webcam for this?
Jan 23, 2012. 1:46 PMdjslipmat123 says:
when i download the mac version, it crashes before it even opens :( anyone know a solution? (running macbook pro on osx lion)
Jan 23, 2012. 10:31 AMDuskeniek says:
Very, very cool idea!
About the height of the box: If you would put a mirror in the corner of the box, wouldn't this decrease the height a lot? (I know the mirror/plate/cam is not proper placed but it is just for the idea)
This arrangement could possibly be more comfortable as well, don't you think? open for suggestions
grtz
Jan 24, 2012. 7:53 AMDuskeniek says:
Ow okay thanks for the reply.
I'll add it to my to-do-list and when I do it, I'll make an instructable for it.
Don't expect anything soon though :P
Grtz
Jan 18, 2012. 6:16 AMblaz!ng says:
when i go to calibrate and press the start calibrate button it does nothing.
Oct 7, 2011. 4:19 PMarjay1491 says:
mine crashes when i click next camera. at first it worked but after that everytime i try it crashes. can anyone help me pls?
Oct 15, 2011. 2:56 PMarjay1491 says:
cool :D it works now, thanks
Aug 21, 2011. 4:11 AMfuture-tinker says:
I can't get TUIO to work, I've erased most of the errors but on the last line:
make: g++: \%home\%alexw\%Desktop\%ccv-1.4-lin-bin\\
the makefile compiler says
Makefile:65: *** target pattern contains no `%'. Stop.
Please help!
May 23, 2011. 8:50 AMtinker234 says:
help me and my freind spent 48 hours working on the program nothing just a bit of help also if the this works could i project the image onto the surface
Aug 25, 2010. 3:46 PMElement1604 says:
Can you still use a built in webcam while running this? And are you going to do another instuctable detailing how to use IR in combo with a projection? ~thanks in advance
Jul 6, 2010. 5:55 PMTomcat94 says:
What about us Mac users? Will we be able to do this?
Jul 7, 2010. 3:50 AMTomcat94 says:
How so? Can you elaborate?
Oct 18, 2010. 8:49 PMlockpick says:
All the software will run on macs?
Oct 18, 2010. 8:50 PMlockpick says:
Does this work with other webcams
Apr 13, 2010. 7:17 PMkoebwil says:
I have been trying like crazy to get this to work on my computer, I run ubuntu and I can't get any of these programs to install.  On top of that, the camera I got (logitech c120) doesn't seem to work with ubuntu at all, I'd appreciate any help at all
Feb 6, 2010. 2:38 PMchupitaz says:
This software multitouch is incredible Cerupcat . How you have so much control? How you configure your camera , I built my own multitouch but i dont have control at all. I dont know if you can help me.. sorry for my english
Jan 30, 2010. 4:44 AMdutchboy12 says:
 the software sucks i had windows vista pc there it didn't work i now have windows 7 pc and it don't work i have tried windows xp also it also didn't work =.=
and i tryed tbeta that's even better it won't do anything else than crash it doesn't even start lol
think the software is kinda old
Jan 19, 2010. 3:38 AMmetal43v3r says:
 i have a problem i made this staff but my  computer already have a webcam so i can't use it what should i do???
Dec 17, 2008. 1:09 PMmaxpower49 says:
can you use ir if you want
Nov 14, 2009. 7:28 PMwillrandship says:
IR is starting to sound infinitely more useful in this project, then you could have it be your screen.
Dec 7, 2009. 2:32 PMmikebruse says:
That's the idea behind FTIR, you can use a modified webcam and a projector.
Sep 1, 2009. 7:06 PMjamesking says:
Can the author contact me ?Or someone who can design the software can also contact me: kingfw@tom.com thanks
Jul 31, 2009. 5:19 AMmikebruse says:
What song did you use for the video?
Jul 19, 2009. 11:12 AMUltraSquirrel says:
And would it be possible to use a pen instead of your finger. To keep down size even more? I'm planning to use it for strategy games, but as I might have mentioned I do not wan't to have it as high as yours. And by reducing the height you also need to reduce the screen size. My camera have a Fisheye lens but still. So to point precise a pen would be good...
1-40 of 192next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:cerupcat
