3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Clothespin Gun
In this instructable I will be showing you how to make a precision classroom weapon. It takes a lot of time to create, but if you take your time and make it quality by following my steps, I promise you will be pleased with the results. This will shoot either toothpicks or matches.. this particular model will not shoot the strike anywhere ones but i will soon put up an instructable for one that ignites them when you fire it.
Step 1Gather Materials
Gather Materials
To get started you are going to need to gather some materials that you might have laying around your house.
1) Super Glue
2) Quick Dry Spray (optional)
3) Terrorist Knife =]
4) Wire Cutters (optional)
5) Two Wooden Clothespins
6) A File
7) And Last Of All You Need WAY Too Much Time on Your Hands
37 comments
Mar 13, 2009. 1:28 PMJATDO says:
Why do you need the second clothespin?
Feb 9, 2012. 8:38 AMGigodorias says:
I actually didn't need to use the second clothespin. If you hold down the spring while cocking it, instead of using an extra one, it saves a lot of time and work.
Mar 13, 2009. 7:02 PMJATDO says:
ahhh I see but couldn't you use anything to secure it?
Mar 13, 2009. 7:40 PMdavidnvn says:
Is there a way to carving out the wood on the clothespin? I kinda stabbed myself trying, and it's going REALLY slowly Nice designs, by the way.
Feb 9, 2012. 8:34 AMGigodorias says:
I actually used the regular cone-shaped sanding/deburring tool on my Dremel. I made a base, or a small root in the wood, then used sanding paper like a maniac.
Nov 10, 2009. 6:40 AMWafflicious says:
I use a small jig saw
May 25, 2009. 11:17 AMracecar96 says:
carve away from yourself in small slits
Apr 17, 2009. 6:40 PMCrakur says:
try using an exacto knife with a flat blade, use it like a chisel
May 25, 2009. 11:18 AMracecar96 says:
i have one of those do you meen the saw add on
Apr 19, 2009. 10:42 AMzoltzerino says:
dremels can be used for anything... even constapation (with the whisk attachment). ZZZZ
Apr 13, 2011. 12:20 AM2qwe2 says:
how long is took u
Oct 23, 2010. 12:46 AM12345123451234567890 says:
can u use a plastic clothespin?
May 19, 2010. 8:58 PMapplefritters says:
Actually, you can ignite strike anywhere matches when you shoot. to do this, place the head of the match in, and make sure the spring part that shoots the projectile hits the head of the match. hope that makes sense...
Mar 10, 2009. 8:24 PMkwlweapons says:
what did you use as handle for the one that looks like a pistol
Mar 12, 2010. 12:40 AMAGT563 says:
samrai have you tried tiping your darts with steal that's what I did with the darts for my mini crossbows wich are about the same size as your clothespin gun and they will stick into people and many other things but dant try it if you dont want it to hurt a bit.
Mar 12, 2010. 12:27 AMAGT563 says:
Hay samarai I think your clothespin gun is cool I my self have made several mini crossbows they are about the same size as your clothespin gun my cross bows have good range depending on the darts I use the darts have a flat and sharp steel tip and they hurt I shot my self in the hand wile testing a prototype it's release mechanism had a mind of it's own a friend told me to shoot him with one and the dart stuck in.
Feb 25, 2010. 4:52 PMaustin_rules says:
 sweet
Jan 12, 2010. 9:20 AMswimmer95 says:
does the pistol shoot?
Dec 12, 2009. 6:33 PMColonel88 says:
Watch out so you don't make the flat curved out thing on one of the sides too deep. If it is too deep, then the metal spring thing will avoid the match and just go over it. DOn't make it too deep! I did  that on my seond try... 1st one wasn't that accurate, went left, eight, and straight.  Oh well. Good job by the way.
5* and faved.
Dec 2, 2009. 12:49 PMzombie1 says:
these are the best made ones i've seen
Oct 25, 2009. 8:39 PMcoolman35 says:
hi samarai this is cool but how do i make the pistol
Nov 10, 2009. 6:39 AMWafflicious says:
Turn it upside down then put a Handel on it.
Aug 28, 2009. 4:52 AMknex_mepalm says:
i really wanna make this but my dad says im too young for projects, now to sneak some stuff, i got the glue, the file and the time, now to sneak out some knives
Jul 22, 2009. 10:41 PMiAmCamYee says:
does your guns have trouble reloading?? mine always
Jul 1, 2009. 11:57 AMluneytune900 says:
wow!!!...thats rele kwl!!!....i make these all the time but not like that!!!
Apr 17, 2009. 6:41 PMCrakur says:
1. nice one, im about to make it! 2. you could hurt yourself if you shot it at someone?0_o
Jun 6, 2009. 1:05 PMAklash, The hunchback says:
ya, if you shoot someone you could hurt yourself(i.e. you shoot them, they hurt you)
Apr 29, 2009. 9:03 AMheheheq says:
DAMN! I love it. It is amazing. THough, one thing, you should make the clothepins a little strong by plating it with metal, because somethimes the fronts sanp if you use it a lot
Apr 24, 2009. 6:34 PMLemmonz says:
dang i cant get it with then knife...any other way i can carve?? that easier lol
Apr 24, 2009. 6:41 PMLemmonz says:
nvm lol i got it
Apr 15, 2009. 5:44 PMJupitane says:
so will it light when you shoot it?
Mar 24, 2009. 6:57 PMActiv-ate says:
how do u make the pistol one?
Mar 12, 2009. 2:30 PMREA says:
lol terrorist knife
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:samarai
