loading
How to Make a Color-Changing Lighted Faux Fur Scarf
Featured
Picture of How to Make a Color-Changing Lighted Faux Fur Scarf
Here are some tips for creating a fuzzy illuminated scarf with color-changing LEDs, with a relatively simple process that is suitable for someone with limited sewing or soldering experience.
The lens of each of these RGB LEDs contains its own red, green, and blue emitters, and a built-in processor to make it blink or fade between colors, so you can achieve a fairly sophisticated effect with a simple circuit, and no external driver. The flexible connecting wires are concealed by a fabric lining, so the finished product is very comfortable and easy to wear. The lights create a nice diffused glow in the fur - wear it as a conversation piece, fashion statement, or safety accessory.
The number of lights in the design can be scaled up or down, with no need for a current-limiting resistor, although battery life will decrease as you increase the number of lights (unless you upgrade to a larger 4.5V supply).
Step 1: List of materials
Picture of list of materials
Sewing materials and tools:
piece of faux fur for scarf (60" x 9" for the example shown)
fabric for lining (60"x9", or can be more of the same fur)
extra fabric for battery pocket
strip of velcro, approx 3" long
sewing needle
thread
scissors
pins
razor blade (to cut fur, optional)
sewing machine (optional)
buttons (standard 2-hole sewing type, approx 1/2" diameter - not rubber, not metal. most plastic buttons are reasonably heat resistant. available at craft stores, or by the pound at buttons4u.com)
Electronic materials and tools:
color-changing RGB LEDs (the type with a built-in flashing or fading circuit, with two external leads - a fast blinking version is available at allelectronics.com, slower fading versions are available on eBay)
battery holder for 3 AA cells, batteries
on/off switch (optional) SPST pushbutton (non-momentary)
insulated connector wire (stranded wire in the range of 20-24 GA - can be obtained by separating pieces from standard ribbon cable)
soldering iron
solder
wire cutters
wire strippers
tweezers
helping hand stand with spring-loaded clips
Other stuff you'll need:
soft surface for pressing LEDs into buttons while bending leads (electrostatic work mat or yoga mat)
hot glue gun and glue sticks
pen or marker
Step 2: Plan light layout
Picture of plan light layout
Decide how many lights you want to install, and where you will put them. They may be concentrated at the ends of the scarf, or distributed along the whole length. If your fur has a texture or color pattern (such as the polka dots in the example shown), that can be used as a guide. Avoid putting lights too close to the edges, or you'll make it difficult to attach the lining. A minimum border of about 1" is recommended if you are handsewing the edges, or 2" for machine sewing.
In these directions, we assume that a battery voltage of 4.5V will be supplied to the scarf (from 3 AA cells), and that all of the lights are connected in parallel with no current limiting resistor. The battery pack will be mounted near one end of the scarf, where the weight is not particularly noticeable compared to the weight of the faux fur.
Other variations are possible, of course - you can mount your batteries near the middle of the scarf, or use a higher driving voltage (such as 9V) and split the lights into two groups that are wired in series.
Battery life will depend on the number of lights and the battery type. A pack of 3 AA cells will power 50 RGB LEDs for several hours.
Step 3: Cut fabric
Picture of cut fabric
Cut two rectangles the same size: one of faux fur and one of the lining fabric, including about 1/2" for the seam allowance around the edge.
The scarf shown here has dimensions of about 60" by 9". We chose the 60" measurement to match the typical purchased fabric width of 60". If your fabric width is 45", you can make a shorter scarf or piece the fabric together. Save some extra fabric for the battery pocket that you'll build in step 9.
To cut faux fur with a minimal amount of shedding, use a razor blade on the back surface. Then, reduce shedding further by finishing the edges of the fur with a serger (overlock sewing machine) or a zigzag stitch.
Step 4: Poke LEDs through fur, secure with buttons
With the head of the LED on the outside of the fur, separate the fur and insert the leads gently so that they stick out on the other side and remain parallel to each other. Do not poke the leads through the same hole in the fur - there should be at last a few threads in the gap between them.
If you have trouble poking the leads through, or they seem to bend too easily, you can make them sharper with wire cutters by trimming the leads at a 45 degree angle. It is important to maintain a difference in lengths, so you can still tell which one is the long lead, or (+) in the next step.
On the back side of the fur, secure the LED by placing a button over the leads. Use a soft surface behind the LED (such as a yoga mat) to press the button into the back of the LED, and gently fold the leads down to the surface of the button. Keep track of which lead was the long lead, and mark the polarity with a '+' or a dot on that side of the button.
When folding the leads onto the button, you want to provide some structural stability and make it easy to solder to the two separate leads without causing an electrical short between them. So, it is recommended that you fold the leads away from each other, at right angles to the axis of the LED.
After the lights are secured with buttons, and the polarity is marked, trim the leads so that they extend almost to the edges of the button. Repeat this process for all lights.
Step 5: Prepare wire connections
Picture of prepare wire connections
The lights are then joined together in parallel, with one set of flexible wire links between all the (+) leads, and a second set joining the (-) leads.
First, make a chain of wires to connect all the (+) leads. Cut the wires in the lengths you will need, allowing at least 10-20% excess length (more slack may be needed for stretchy fabrics). Strip about 1/4" of the insulation away from each end of each wire and twist them together tightly in pairs, end to end in the order they will be joined to the lights. This step is easier if the spacing between all the lights is uniform. If your light spacing is variable, keep track of where the segments belong as you make them.
Pre-solder the twisted junctions, making a decent sized solder blob adhere to each twist. This step is much easier if you can clamp the twisted junction with a set of helping hands or similar device.
Make a second copy of this chain for the (-) leads.
As noted in the list of materials, it is strongly recommended that you use stranded insulated wire. Solid-core wire does not withstand repeated flexing very well, regardless of wire thickness. If you use non-insulated wire or conductive thread, you will risk short-circuits when the wires move and touch each other.
Step 6: Attach wires to LED leads
Picture of attach wires to LED leads
Solder the wire linkages to the trimmed LED leads on the buttons. For each joint, hold the twisted end with the solder blob next to the LED lead, pressing down to make the wires parallel to the surface of the button. Hold with tweezers, if necessary. Heat it until the solder flows, and then remove the soldering iron tip and hold the wire junction still while the solder cools.
If the wire has been prepared with a big enough solder blob, then you will not need to add solder in this step, making it easy to do with two hands.
The button should act as a heat barrier, and protect the fabric while you are soldering. Use caution to not drip hot solder on the faux fur (acrylic melts!).
Note that the wires are oriented so that the insulated wire adjacent to the solder joint is supported by the button, rather than hanging off the edge where it will be vulnerable to damage.
Join all the (+) leads with one chain of wires, and join all the (-) leads with a second chain. Trim sharp points as needed.
Step 7: Attach battery pack
Picture of attach battery pack
Connect the power (+) and ground (-) portions of the circuit to the corresponding leads on the battery pack. Turn the lights on to verify that the polarity is correct. There should be enough slack in the wires so that the battery pack can be pulled a reasonable distance outside of the pocket to change the batteries.
If your battery pack does not have a built-in switch, and you would like to add one, you can insert a standard pushbutton or toggle switch at this stage. If you can't find a 3 cell AA holder, you can make one from a 4 cell holder by joining two of the battery contacts within one of the cells.
Step 8: Seal solder joints
Picture of seal solder joints
Once you are satisfied that all the lights are working properly, seal the backs of the solder junctions with hot glue. Use a thick coating, making the glue into a smooth round surface that flows over the edges of the buttons. Don't let the middle sections of the other wires get stuck to the glue on the buttons, that may interfere with the slack that was built into the design.
The glue offers strain relief and electrical isolation, and will protect the electronics from exposure to moisture (sweat or rain) when the scarf is worn, and will provide some protection during washing. Overall, I'd recommend that you spot clean or hand wash the garment in cold or warm water, and dry it flat. This type of assembly will probably survive mild machine washing at cold temperatures, but the life of the garment will be reduced by repeated tumbling and twisting, and exposure to soap and other chemicals will eventually cause the LED leads to become corroded. Dry cleaning is not recommended.
Step 9: Build battery pocket, attach to lining
Picture of build battery pocket, attach to lining
The battery pocket should be slightly bigger than your battery pack, but not too much bigger since you don't want it to move or bounce around a lot while you're wearing it. For example, allow about 1" extra on three sides, and 2" extra on the side where the velcro closure will be. Cut out the pocket from fabric that matches the lining. Finish the edges with an overlock or zigzag stitch, and sew the velcro strip along one edge of the pocket.
Position the pocket where it will go on the lining (near the battery pack) - sew the matching velcro strip on the lining, then sew the pocket in place.
You can substitute a button, snap, or other closure for the pocket, but it is important to have a way of keeping the battery pack from falling out and dangling, since this can damage the connecting wires.
Step 10: Finish sewing scarf lining
Pin the fur and lining pieces together, with the right (outer) sides facing inward. Stitch most of the way around the edge, leaving a gap that is near the battery pocket, and big enough to turn the scarf right-side out through that hole. If your battery pack is at one end of the scarf, just leave that end open.
Machine sewing: Keep the electronics on the top side when you are sewing around the edge. This will help you keep track of the wires, and make sure you don't sew through them or get them caught on parts of the machine.
Hand sewing: Use heavy duty thread, and an overhand stitch.
After the fur and lining have been joined along three seams, turn the scarf right-side out.
Cut a small slash in the inner (lining) side of the pocket, and pass the battery pack or snap connector through this hole. Hand-sew the slash closed so the battery pack cannot fit through the hole again. Hand sew the remaining open edge of the scarf.
Step 11: Photos of finished scarf
This long scarf is versatile, and can be worn many ways. Enjoy!
uloixia1 year ago
Thank you so much for showing exactly how you wired the LEDs. So many people just put up the schematic and leave you to your own devices, which, in reality, isn't all that helpful.
And what an awesome scarf! Can't wait to make some franken-version of this. :)
AnnaOnWeb6 years ago
Congeniuos! Looks good, is working perfectly... BUT: Can you give me a hint where to get this very special faux fur? I have not found anything else which would be appropriate to this project. Thanks A Lot! With best regards, Anna
Moodfabrics.com
enlighted (author)  AnnaOnWeb6 years ago
hi- I'm sorry, I've looked but have never seen that particular fur online. I found that type while shopping in the downtown LA garment district (one of the main places with big rolls visible from the street). -Janet
I just moved to Cali and was thinking about going down to LA to buy some fabric. Any recommendations of stores down there? Thanks! Erin
enlighted (author)  rei00426 years ago
The corner of 9th St and Maple Ave in downtown LA has a few good fur shops, and there are many other fabric shops in that general area.
Hi Janet, thank you for your answer. I will have a hard time to get an appropiate faux fur for that. I alread planning the scarf to be powerde by a lithium polymer accu which causes some difficulties ... the burst into flames occasionally. When I get a solution working and tested it would be a pleasure for me to provide it to you - such a lipo accu has less weight and much more power. Have a nice evenig - it´s around midnight here right now - and with my best regards, Anna
All the color-changing LEDs I can find have three leads not two. Where did you find the LEDs used in this?
 thats epic
gregod436 years ago
What about resistors? Or at least one resistor to restrict current? You may be able to get a more effective scarf with longer life if you try that out.
enlighted (author)  gregod436 years ago
For a single-color LED, yes, resistors are a good idea. However for the type with built-in color-changing, they work fine with a direct 4.5V power source. I have some pieces built by this technique that are several years old, and all the LEDs still work.
mpinner6 years ago
great repurposing of buttons! i've done some led fabrics and a few buttons would have really helped to keep them aimed properly. thanks for the ingenious idea.
Goodhart6 years ago
That is both wild and very well done......thank you for this
dr.light7 years ago
the RGB blinkers @ ALL ELX actually have more than 1 mode... they will cycle thru a quck-snap (or bump) but with them also cycle thru a xfade mode. I used a bunch of them for my light up santa camp marker @ Burningman 07 bonus points for crashing the microcontroller in them and getting them to 'stick' in a mode or color...
mu0p7 years ago
AMAZING thnx for the enormous amount of detail!!! really well put together!
terren2727 years ago
this is katya!! omg i loove your work on this one the leopard... and the lights...and the furriness!! omg i loove it!!!! youre amazing! :D
Zujus7 years ago
Awesome job! Nice fur pattern ;)
Great job! I love all the detail you put in here.
canida7 years ago
This looks great! Very nicely done, and carefully explained.
Awesome! I would so do this if I had that scarf... nice scarf by the way.
