Introduction: How to Make a Companion Cube
Step 1: Gather Your Supplies.
You will need: perler beads (white, pink, dark grey), a hot glue gun (with glue sticks), perler pegboards (a circle and a square one), an iron, and ironing/wax paper.
Step 2: Make the Corner Pieces.
Make the white corner pieces by placing the beads on the pegboard. There are 3 different pieces per corner - these 3 pieces will snap together and make one corner. You will need 8 corner sets total. Use the picture above for reference.
Step 3: Fuse the Beads.
Fuse the beads by placing a sheet of wax paper over them. Gently iron them at medium heat for a few seconds. Flip the fused beads over once one side is finished, and fuse the other side. Both sides need to be fused! *Make sure you don't over melt the beads or they will be unable to "snap into place" for the 3D effect.
For a more in depth explanation of the fusing process, visit the linky.
http://www.ehow.com/how_6778903_iron-beads.html
Step 4: Make the Edge Pieces.
There are 2 pieces in one set. You will need 12 edge sets. Use the picture for reference. Fuse when finished.
Step 5: Make the Circles.
You will need 6 circles total. Fuse them when finished. Use picture for reference.
Step 6: Make Square #1.
You will need 2. Fuse when finished. Use picture for reference. (The outline is just for emphasis on the detailed "teeth" portions.)
Step 7: Make Square #2.
Step 8: Make Square #3.
Step 9: Make the Hearts.
You will need 6 total. Fuse when finished. Use picture for reference.
Step 10: Snap the Corner and Edge Pieces Together.
Step 11: Snap the Grey Squares Together.
You will now have a 3D cube. *Be gentle, don't break the "teeth" pieces while snapping them together.*
Step 12: Hot Glue Hearts to Circles.
Make sure the hearts are centered on the white circles. Hot glue them together.
Step 13: Glue on the Corners.
Glue the corner pieces to the 3D cube.
Step 14: Glue the Edge Pieces to the Cube.
One per edge. Align them with the pink lines on the square faces.
Step 15: Glue to Heart Circles to the Cube.
One circle per side. Voila!
