loading
Step 3: Shaping and Parting Off
Start shaping the handle however you want, keeping in mind that there's a hole running through the piece. As you get closer and closer to the diameter of the hole, start making very frequent size checks to make sure that you aren't getting too close. 1/64" to 1/32" is a good wall thickness to have at the tip of the handle.
<p>Thanks for your help. really helpful, I made mine out some orange Osage with an aluminum shaft. Used one of my pen inserts, so the shaft goes all the through. Made it easier to balance also. </p>
I got the idea for my band intern befor he leaves as a goodbye gift but I don't know how to make one
My dad and I made my lathe. Been selling pens to buy a trumpet, and actually thought of doing this before even coming to this site. Weird.
<p>wow!! (*0*)</p><p>thank (^-^)b</p>
Thanks
Wow this looks amazing I'm in 8th grade and I was looking for something I could get my band teachers now I know! Batons and matching pens I'll turn!
Fantastic! I made my first baton in 8th grade too :) Have fun!
A very excellent baton job you should have asked to be Featured.<br> The first lighted baton I made used a smaller El_driver and coin battery.<br> Here is the one <a href="https://www.instructables.com/id/GLIMMER-MAGIC-LIGHT-WAND/" rel="nofollow">made for Halloween</a> .<br> <br> A
Wow, it's lovely! For some reason I never thought of using EL wire, even though I've been trying to make a lit baton for years. Thanks for the idea!
im making a brass one for my girlfriend and the angle feature of a metal lathe comes in handy here but i still need to smooth it out with a file
Oh cool! How'd it turn out? I've actually been able to turn brass and other metals on a good ol' wood lathe, the tools just need more frequent sharpening.
thats a purdy chuck you got there
Any way to do this without a lathe..................... we dont have a woodturning club or anything like that around here..... i actually dont even have any idea how to use a lathe but this looks like an awesome gift for my my band director..........
Do you have access to a hand drill (or, even better, a drill press)? If you do, you can definitely make the shaft, the handle's a bit harder. Try drilling a 1/2&quot; diameter hole 1&quot; or so deep in one end of a piece of wood (enough to be secure) and glue in a dowel or metal rod. With the drill clamped in a vice, securely strapped to a table, or what have you, put the dowel in the drill chuck and tighten it down. Since you won't have a tool rest, I'd recommend using various rasps, files, etc. to get it down to the shape you want, and then proceeding from there with sandpaper.<br> When drilling the hole that connects the handle to the shaft, you should probably start with a small bit (1/16&quot; or so) just to get the hole started, then move up to 1/8&quot; and finally 3/16&quot;. This should make your life easier because each bit is only removing a small amount of wood at a time, thus requiring less force each time you drill. First, make a dimple in the surface of the wood with your files to help guide the drill bit. Now, using a pair of pliers or vice grips or something that's not your fingers, get a firm grip on the drill bit and push it into the spinning wood. This will require a fair amount of pressure, but if you do it in steps you should be fine. Drill to the depth you want, repeat with the other two bits, and you're done!&nbsp;<br> Finish sanding through the grits, add a finish if you want to, part it off, and glue the two pieces together.<br> <br> Also, if your school (I'm assuming you're still in school, sorry if I'm wrong) has a shop, talk to the teacher there and see if they have any suggestions. They might even have a lathe :)<br> <br> Hope this helps!
thanks for replying i could talk to the shop teacher for sure maybe borrow some tools or get on the lathe. I appreciate all the help i will be sure to try that!
Sure, anytime. Good luck!
u mean thats how to make the thingy the fancy crazy guy waves around during an orchestra?? cool :)
Heh, sure is. Nice description btw ;)
What a great gift! As a (former) music teacher this would be something I'd be proud to get. One of these days I'll get around to playing with a lathe.
Glad you like it :)<br> <br> Heck, when you get your lathe we could start our own baton business to rival Mollard! :P
Sounds good to me. I've been looking for a new line of work anyway! We'll definitely have to get that balance down. Conductors are picky about that. :)
Awesome! Heh, I always over sand the shaft and end up with batons that are just barely too heavy in the handle.&nbsp;
Nice work, sweet lathe, having some tool envy here.<br>
Thanks! Maybe it's time to add a lathe to your tool collection ;)
I've got a 47&quot; mono rail lathe, but I really want a jet like yours.
See, you've got a nice long bed though :)<br> I got mine when jet was having that promotion a while back for $100 off or something, it's a 1220vs. But it looks like a bunch of other companies have raised the bar for their lathes too (notably psi's <a href="http://www.pennstateind.com/store/TCLC12WB.html" rel="nofollow">turncrafters</a>, and I hear the deltas are pretty good too)
I have chuck envy. I have a 60&quot; craftsman with a 20&quot; turning capacity, but no chuck...
Aw :(<br> Well, congrats on your awesome lathe first of all. If you look around ebay and stuff you'll probably find a nice chuck for fairly cheap. If not, psi has some nice looking ones <a href="http://www.pennstateind.com/store/CUG3418CCX.html" rel="nofollow">here</a> and <a href="http://www.pennstateind.com/store/CSC2000C.html" rel="nofollow">here</a>, and if you scroll through <a href="http://www.woodturnerscatalog.com/store/Chucks?Args=" rel="nofollow">here</a> you might find something that catches your eye as well :)
I do have a lot of delta tools and I always liked the look of the midi they make, but hey, you got a Jet....need I say more?<br>
Haha, good point :)
Very nice and well done!
Thank you very much! It's an honor to hear that from you :)
I've been looking for good instructions to make one of these! Now if we only had a lathe... Nice job.
Thanks! Glad I could help :)<br> <br> You might be able to find a <a href="http://www.woodturner.org/community/chapters/LocalChapters.asp" rel="nofollow">local woodturning club</a>&nbsp;and see what their policy is on shop time (for the one near me, they have &quot;skill enhancement&quot; sessions twice a month where you pay a $5 shop fee and get to use all the tools, and there're experienced members there that are more than happy to help out),&nbsp;or you could go to your local wood store (woodcraft, rockler's, etc.) and take a woodturning class.
About This Instructable
36,536views
49favorites
License:
Bio: I like to make stuff and learn through the process. That's pretty much it :)
More by gg1220:3D Modeling an Instructables Ring How to Make a Wooden Folding Knife Chainmaille Rose
Add instructable to:
