3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Corsage
Step 4Make More Layers
Make More Layers
Before you put on the bow, you may want to "layer" your work to give it a more glamorous feel.
Cut 2 pieces each of Satin and sheer ribbon. Cut the ends at an angle. Cross the ribbons, so each end is alternating with a different texture. Tack(sew) the middle, and add embellishments.
I hot-glued some snowflakes and clear beads on the ends.
When finished, sew, or hot-glue to the bottom of the mesh base.
On the top side of the bottom sections, I opted to make a feather ribbon circle. Hot glue it onto the mesh material, being careful not to burn your fingers, or stick it to the work surface. Use some scrap pieces of sating ribbon to push the circle onto the glue.
(In the pictures, I glued the circle before the bottom piece.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:Very Interesting
