How to Make a Cutter From a COMPUTER
8,471
110
Published
Introduction: How to Make a Cutter From a COMPUTER
About: https://www.youtube.com/dashboard?o=U
https://www.youtube.com/watch?v=IwmN90qkwE4&feature=youtu.be
Step 1: To Do a Cutter From a COMPUTER You Need!
To manufacture a cutter with your own hands we need:
- Power supply 12V 5-10А from PC or another device;
- Nickel-chromium wire with the section of 0,4 – 0,8 mm;
- Wooden handles or 2 pieces of a branch;
- 2 nails or 2 lengths of a firm wire.
Step 2: In This Instructables I'm Going to Show You How to Make Nickel-chromium Electric Fret-saw or a So Called Cutter.
Step 3: With the Help of a Hand Made Electric Fret-saw You Will Be Able to Saw Out, Burn Out Beautiful Frames, Wooden Jewel-boxes, Which You May Present to Someone.
Step 4: You Will Also Be Able to Cut Plastic, Foam Plastic Etc. Evenly With the Help of a Hand Made Fret-saw.
Step 5: Hand Made Electric Fret-saw Is Very Easy to Manufacture and to Work With!
Step 6: I Hope That Some of You Will Make the One for Himself and Remember Me Well...
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    2 Comments
    nice hot wire cutter. don't forget safety info, a lot of kids use this site. some may be irresponsible and burn their house down trying to cut random objects with it...
    I suggest adding a momentary switch to a handle so if its dropped it will turn off.
    Great idea thanks :)
    If I were to make one it would be to use on blue or pink foam. Of course, proper ventilation would be needed as the fumes are toxic.
    Thanks again for this :)
