3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a DIY Spray Paint T-Shirt
Step 4Spray Paint (Part 2)
On the other side, use the cut outs and spray paint.
3 comments
Oct 8, 2009. 12:39 PMlenalandmine says:
I'm not 100% sure, but I believe in this video, he isn't holding/taping/adhering the stencils down in any way. They're made of posterboard and he's painting almost completely perpendicular to them so the paint isn't making them move around, plus, he's doing thin layers. It also doesn't appear to be the slightest bit of wind, which will help. I personally *love* using freezer paper. You iron it on, slick side down, to your fabric and it'll stay until you peel it off. It won't leave a single bit of residue, and there's no way your paint will bleed. Plus, it's cheap as hell!
May 15, 2009. 6:19 PMKilldoomkid says:
Hey, I make spray paint t-shirts a lot but I still haven't figured out a more convenient way of making tiny stencils (like the ones in this photo) to stick without using my hands. Any suggestions? Is tape the best way?
Aug 23, 2009. 9:57 AMsmittybryson says:
Hey use blue painters tape, it is easy to shape rip and cut the way you want it :)! also easy to peel
Jul 9, 2009. 5:24 PMjaredisasushi says:
Not sure if I get your question but I think you are asking is there a way to hold the stencil to the shirt without using your fingers? I move forward with that question. I use two different ways when this is necessary. 1. If it is for a stencil I am only going to use once(maybe a few times) and it is small enough I actually carve it out on 2 inch masking tape. The tape holds it pretty well and prevents bleedding pretty nicely. This method is also nice because you can stick the tape to the surface you are cutting the stencil on and you don't have to worry about the paper flying around like it does. 2. If its for a permanent stencil I use a fabric adhesive that holds the stencil to the shirt but will wash off later. I don't have any right now or I would give you a brand name, I am pretty certain you can find it at most art/craft stores. Taping down the stencil will also work but that will make it easier for paint to slip under the stencil. Hope this helped.
May 25, 2009. 2:19 PMBigChingadero says:
A coat of spraymount, like 3M 77 spray, is good. Let it dry before you stick it down, so that the goo doesn't get into the fibers. It shouldn't leave any appreciable residue on the shirt.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
799
Author:threadbanger
Threadbanger is a network for people who love to DIY, recreate, refashion and craft. Forget about corporate stores, we're here to help you create and find your own style! From our episodes, forum and ...
more »
