How to Make a Dedicated Garry's Mod Server(Windows)
 by xXcAsPaXx
This is one way to make a dedicated server for Garry's Mod via port forwarding instead of using a hamachi client. The benefit to this is that anyone can go on your server, as long as you allow it. I will also teach you how to set permissions as well so you can lock people out too.
Step 1: Download and Install the Half-Life Dedicated Source Update Tool.
Download the Half-Life Dedicated Source Update Tool here then run the program.
When installing change the destination folder to "C:\srcds" by clicking the "browse" button and then at the top of the window that says "Select Destination Directory" change whatever is in the top bar you can edit to "C:\srcds (If the file does not exist the installer will make the folder for you).
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
