3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Fake Hand
Previously on Indy Mogul, we showed you how to make a fake head for your indie filmmaking needs. This week we have the recipe for a fake hand! We are always looking for new projects like these at Indy Mogul, so send in your ideas! And don't forget to subscribe to our podcast on iTunes!
Shopping List
1. 16 lbs. plaster of paris.
(8 lbs for the top half, 8 for the bottom. )
2. BFX ballistics gel.
(Check out this Weekend Extra for more details.)
3. Liquid latex.
(In a flesh tone.)
4. Caulk.
(Does not need to be adhesive.)
5. Petroleum Jelly.
(As a de-molding agent. You could also use cooking spray.)
6. Duct tape.
(I'm going to stop listing this because you should always have some ready.)
7. A cardboard box.
(To add some "fleshyness" to the face.)
Step 1The Mold (Part 1)
The Mold (Part 1)
This process takes several stages, but is fairly simple. First cut a notch in one end of the box. Then tape up the bottom and sides.
Next mix up half your plaster, which should be about 8 lbs for a hand mold. As mentioned by Jared, use a little more water then recommended. Cover your subjects entire hand and arm (anything going into the plaster) with petroleum jelly. Now pour your plaster into the bo. It should be about 3-4 inches deep. Place the bottom half of your hand into the plaster and rock it back and forth to get it to sink in. Don't put your hand too deep into the plaster.
23 comments
Jun 10, 2011. 5:45 PMskaar says:
how about painting the inside of the mould with the latex first? then add the gel...
Jan 20, 2012. 8:30 PMmiss janel says:
if you were to paint the two halves of the mold before you poured the ballistics gel there would be a seam that would be fairly unattractive, though painting it on isnt very smooth either, theres always the option of buying a larger ammount of latex and dipping the gel hand into that but ive not much experience.
Mar 2, 2012. 5:43 AMskaar says:
i was thinking that it could be poured into the mould, and the latex rotated around it, then pour out.
Aug 6, 2011. 7:15 PMndeclares war says:
I was thinking the same, seems like a great idea.
Feb 25, 2012. 9:48 PMtinker234 says:
wow you know your brain epsiode got me thinking the mould and silcone could mean a prop thats is usable over and over
Aug 8, 2011. 11:32 PMskaar says:
how about alginate, it cures fast, pour it on the hand, wrap some plaster soaked gauze around that, when it cures, slit it up the side...
Nov 8, 2010. 2:33 AMezginori says:
Thank you for the instructable. It was the only good instructable to take the mold of my hand usuing plaster. I must admit at first I didnt take your measurements seariously. I mean that much of plaster, then I was struck by the reality, I didnt have enough plaster for the top, so it broke. So everyone, you really need that much, not less. In addition, there are three details I would like to point out about molding: One is to be careful while choosing the plaster of paris. There are too many types, the fast drying one is the one for repair. The other thing is the hint of mixing the plaster. Always put water in to the container first, then cup by cup add the plaster. So you wont have lumps. The mixture will be saturated eventually.It has to get a yogurt type of feel. Since it dries really fast you have to be quick. The last thing is, that you mix the plaster always in the same direction. For ex. clocwise. If you mix it with towards both directions, your plasters quality will be poor. So it can crack or break easily. I hope these hints are helpfull. Thanks again.
Jul 7, 2008. 9:36 AMRye says:
Can i use this for a jello mold?
Dec 5, 2008. 1:49 PMKankuro says:
i'd think so, as long as you put plastic wrap or tinfoil inside the mold first.
May 13, 2009. 10:52 AMThenwcp says:
HAHAHA JELLO FOOT
Jun 18, 2009. 5:38 PMArgool says:
I could use this to make an edible fake hand! this year's halloween costume: Jelloman
Jun 10, 2009. 3:08 AMFashim says:
Lol Awesome im gonna use this to beat people lol
Jun 7, 2009. 4:03 PMJR.Mythbuster says:
hey, do you put your hand in cardboard box full of plaster and then let it sit till dry then pull out your hand?dont get mold making.can somebuddy help please?! S.O.S LOL! but really can someone break it down for me soon please?
May 11, 2009. 10:39 AMkomal00 says:
this stinks
Sep 2, 2008. 9:28 PMpipotoy2004 says:
It's great with zombie makeup!
Oct 25, 2007. 4:43 PMbethehammer says:
Is that wire inside the fingers? Is that to make it stiffer? What is the shelf life of the limb? It looks like you are using knox gel, isnt that a food product?
Jul 9, 2008. 10:23 PMArisenProdigy says:
I'm in the process of creating ears for a bi-naural sound project. I have the plaster molds of my ears (which hurts a lot, btw) but I'm also curious about how long knox gel will last. Heck, maybe I'll use latex caulking to fill them in and use that as the mold...
Mar 3, 2008. 9:15 AMOldFatMarriedGuy says:
can you save on plaster(and make the mold lighter) by pre-filling the dead areas of the mold with scrap styrafoam? or would this increase the likelyhood of the mold cracking?
Oct 28, 2007. 6:58 PMWurdBendur says:
I never bothered to use anything like caulk on a plaster mold. A big rubber band will hold it well enough, or you can just tie it, or tape it, or whatever. Also, adding the caulk will create extra space between the halves of the mold, which you don't really want. So is there a particular reason you use this? Does your ballistics gel tend to leak out a lot?
Oct 5, 2007. 12:00 PMRobot Boy says:
If you're going to make two halves of a mold, maybe you could poke some finger holes around the outside of the hand to line up the two halves when they're done.
Sep 22, 2007. 1:47 PMDarkshot says:
how long this take you?
Aug 24, 2007. 12:51 PMJakeTobak says:
Where can I get the Ballistics gel?
Aug 24, 2007. 1:37 PMRamnosity says:
I've made ballistics gel out of Knox brand geletan.
Here is the link on how to make it. It will melt after a while though so keep it in the fridge when not in use. http://www.myscienceproject.org/gelatin.html
You can also buy Real gel from a movie FX company. It's about $350 for a 50 lbs. bag.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
472
Author:indymogul
Indy Mogul is the network dedicated to DIY filmmakers and film lovers alike. Our first show, Backyard FX, is a creative and funny 'how-to' guide for making film effects on the cheap. New episode every...
more »
