3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Feather Quill (2 ways)
  • last photo ←
Dont worry this does have to do with halloween! This could be a great prop If you needed to do some writing at a haunted house or halloween party !Here are two simple ways to make a fake and real feather quill or pen. These can be used in a witch or wizard costume, if you are doing some sort of big setup or haunted house or something that involves writing. They are really easy and virtually free to make!
First of all you must pick the right feather, the bigger longer and fatter the feather the better, although for the fake quill, the stem has to be relatively thin.
Step 1The Real way
The Real way
Making a traditional feather quill is not hard. Really the only thing hard is learning to write with one. The tip is flat so you can only draw down strokes. It leaves you writing in Gothic script but it still looks cool and is fun, but not very practical for everyday note-taking and stuff like that. All you need to do is cut a diagonal cut (with scissors or a small knife) across the tip of the feather, you will be writing on the pint of this tip. You can make it a little wider for calligraphy or thinner for normal writing but remember, you cant draw going up sow your going to have to work out some sort of gothic script. I learned by the picture below.
14 comments
Nov 22, 2009. 7:27 PMXysrvrsch says:
Great instructable!
What kind of ink are you using with the real quill?
May 14, 2011. 8:20 PMsrose2 says:
india probably
Apr 27, 2009. 4:49 PMREA says:
in step two, what do you mean by "...you cant draw going up..."?
Mar 16, 2009. 9:43 PMdwhp says:
thank you for this. I made one with this huge feather i found in the field behind my neihgberhood.
Oct 15, 2008. 9:57 PMJedi Ronin says:
Also, this is useful in a ritualistic setting (i.e. Wiccan/Neopagan)
Dec 4, 2008. 4:56 PMdwhp says:
like Ifer said,"Where's you get the feathers?".
Nov 23, 2008. 9:01 PMIfer says:
Oct 14, 2008. 9:37 PMfoxpox says:
oh sweet id never think of that!
Oct 14, 2008. 8:18 PMnnygamer says:
Without tempering the tip a quill will not be sturdy enough for extended use. You can bake (@ 350 15-20 min) or heat on the stove, both in a can full of sand. This will harden the tip and make it easier to carve and last a bit longer.
Oct 14, 2008. 5:35 PMHeWantsRevenge says:
awesome idea there...goto try it next timei fall into some feathers
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:DainiusGB(Hydrogen Art)
