Step 44. 1st Resin and Fiberglass Layer
Prepare your resin by mixing the recommended amount of hardener and resin as listed on the package. You will not want to work with large amount, or change the amount of hardener (you can vary it depending on temperature). I recommend that you use no more than 2 - 4oz at a time. I suggest mixing a batch in plastic cups and working in small areas. You should get about 30 minutes of work time, and good area coverage with the right amount of hardener, and resin.
Once you have prepared your resin, you will need to prepare the fiberglass. This isn't that hard, just rip up the matte into manageable strips, about 1" x 4" long. (Wear your mask!, and some disposable gloves at all times!)
Now you can finally begin. The procedure I used is quite like paper mache if you have ever done that. Take your cheapo brush, and dip it in resin, spreading it over the area your are going to be working on. Then take one of your glass strips and place it on there. Then use your brush again to dab resin onto the strip until it turns more transparent. (Look out for bubbles, if you see white areas bubbling up you have air trapped. Use your brush and try to spread out the air to get rid of it. Air bubbles could make your box boom itself to pieces if its too weak.) Continue laying fiberglass in this fashion, crossing over the other pieces until you have a good layer that covers the taped area. (Remeber to make your shell bigger than you actually want, you will trim it down later). Wait about 2 hours until it has dried and become touchable. (You can use a hair dryer to help speed up the process!)
comments
Add Comment
Add Comment
