How to Make a Garden Trough (Hypertufa Planter)
19,671
280
Published
Introduction: How to Make a Garden Trough (Hypertufa Planter)
About: The Emmy Award winning This Old House is television's premier home improvement series. The show that unlocked America's passion for home celebrates more than 30 years of home improvement on PBS. The televisi...
Back in 1800s, crafty English farmers used to chisel feeding troughs for their animals out of local granite and sandstone. Nowadays, creative gardeners have adapted these old containers, which are now covered in moss and worn by decades of exposure to the elements, into decorative planters that would make an excellent addition in your garden.
However, trying to obtain one of these centuries-old planters yourself might prove expensive and tricky. Luckily we've discovered a way to create this planter all on your own with materials you can easily obtain. Here's a quick and easy way to replicate the weathered look of these hand-hewn vessels yourself.
The key is a material called hypertufa, a mix of cement, peat moss, and perlite, products readily available at any home or garden center. Just combine the ingredients, add water, pack the mixture into a handmade mold, and set it aside to cure for a couple of days. When you pop off the mold, you'll have created a bit of the Old World, right in your own backyard.
See more planter ideas from This Old House
Step 1: Overview
Time: 1 weekend
Cost: $50
Supplies You Will Need:
1. Form materials: pine shelf board, plywood, foam insulation, or cardboard boxes will work. Beveled panels for decorative recess are optional. (See Overview)
2. ½-inch multi-purpose screws
3. Releasing agent. Melted paraffin or petroleum jelly will work.
4. 2½-inch-tall PVC pipe pieces. Paper towel spool pieces will also work.
5. Cement: (5-9 for hypertufa mix; See "The Recipe" in Overview)
6. Peat
7. Perlite
8. Liquid acrylic
9. Nylon reinforcing fibers
10. Plastic sheeting
11. Wire mesh
12. Seedlings
13. Soil
Tools you will Need:
1. HAMMER
2. PAINTBRUSH
3. GLOVES
4. DUST MASK
5. GOGGLES
6. BUCKET OR PAIL
7. GARDEN TROWEL
8. COARSE WIRE BRUSH
9. MALLET
10. SMALL PIECE OF SCRAP WOOD
RECIPE:
The amount of hypertufa mix you will need depends on the size of the trough you're making. You can stretch or shrink the recipe if you stick to these basic proportions: 
• 3 parts cement
• 4 parts peat
• 4 parts perlite
• Water sufficient to make a firm, moldable mixture, plus a splash of liquid acrylic (about ¼ the amount of total liquid)
• A handful of nylon reinforcing fibers
Building the Form:
Trough forms can be made from plywood, rigid foam insulation, or two cardboard boxes, one inside the other. We used pine shelf board because it is sturdy and can be used again and again. To create the decorative recess, we glued beveled panels to the insides of the exterior form.
Our trough measured 17 inches wide by 24 inches long by 10 inches high. You can use the same method to build any size trough. For best results, the walls should be a minimum of 2¼ inches thick, and the trough should be at least 7½ inches deep.
Step 2: Apply Release Agent
To keep the hypertufa from sticking to the form, the wood must first be coated with a release agent. (For instructions on making the form, see the overview page.) You can use petroleum jelly or a piece of plastic sheeting. We brushed on a layer of melted paraffin. Later, any paraffin residue on the trough can be easily removed with a wire brush or flat putty knife.
Step 3: Create Drainage
To ensure proper drainage, you'll need to create holes in the bottom of the planter. Do this with a paper-towel spool or lengths of PVC pipe, cut into four 2½-inch-tall pieces and spaced evenly toward the corners of the outside form. Use some of the melted paraffin to secure them.
RELATED: How to Drill Drainage Holes
Step 4: Mix Hypertufa Materials
Wearing gloves, dust mask, and goggles, mix the cement, peat, and perlite in a large tub or trough. (For quantities of all ingredients, see "The Recipe" on the overview page AKA Step 1.) Add the water and acrylic fortifier a bit at a time, turning the mix thoroughly so it sticks together but is not runny. Fluff up the nylon reinforcing fibers and add them to the mix. You should be able to form the fiber-reinforced mix into a solid ball that doesn't fall apart.
Step 5: Pack Hypertufa Into Form
When packing the hypertufa mix into the form, take care not to knock the drainage molds out of place. Pack the mix tightly, starting with the bottom. When you've packed the bottom to a thickness of at least 2½ inches, insert the inner form and begin packing tightly up the sides. Shovel the mixture in with a garden trowel. Remember, the tighter you pack, the stronger your trough will be.
RELATED: Turn a Found Wagon Into an Herb Garden
Step 6: Tamp Down Hypertufa
As you pack the hypertufa mixture up the sides, periodically tamp it down with a flat piece of wood to get rid of any air pockets. Continue adding and tamping until the mixture is flush with the top of the outer box.
Step 7: Remove Trough From Form
The trough will need at least 24 hours to cure enough to unmold. When you can't scratch the surface with a fingernail, it's ready. Remove all the fasteners and take off the bottom panel. Then remove the outside walls, popping the boards free of the paraffin with a garden trowel. Push the walls of the inside form toward the center so they collapse inward on themselves.
Step 8: Finish and Wrap
When first unmolded, the trough can be textured. By going over the surface with a coarse wire brush and knocking down any sharp corners, you can add hundreds of years of "weathering" and impart an aged look. Once you've distressed the trough, wrap it in plastic and leave it in a cool place to cure for about four weeks, when it will have reached maximum strength. Then it's ready for planting.
RELATED: Unique and Vibrant Leafy Plants That'll Look Great
Step 9: Start Planting
You can fill your trough with just about any growing thing. Traditionally, they're used for rugged alpine plants, which thrive in the porous containers. Small and slow-growing, yet with beautiful flowers, alpines are well-suited for the limited confines of a trough garden. Good choices are herbaceous perennials and dwarf shrubs and conifers. The important thing when choosing plants is to consider scale and growing habits; you don't want aggressive spreaders that will take over the trough.
The best planting mixture for alpines is organic soil with sand, grit, and small stones. A layer of gravel at the bottom of the trough is optional but will improve drainage. Before filling the trough, put a small piece of wire mesh over each drainage hole to keep it clear. And be sure to leave space in the trough for some native rocks—in addition to looking nice, they imitate the alpine environment, protecting plants from the ravages of wind and extreme temperature swings.
Speaking of temperature swings, try to keep the trough shaded in winter to limit repeated freeze/thaw cycles, which can do damage to plants and also shorten the life of the trough.
RELATED: Make a Hypertufa Table with Built-in Planter
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    3 Comments
    Are the liquid acrylic and nylon fibers really necessary? Would they be necessary in other, smaller projects? What makes them necessary in this?
    Beautiful project and I am looking forward to experimentation.
    Diggin it! Made a rounded one using a small punch bowl inverted and just slabbing the hypertufa mix on. Placed in garbage bag to slow the cure and used it for planting succulents. Have actually seen some really nice hypertufa planters embedded with moss. Thanks for the post. Excellent Mother's Day idea.
