This Glowing Crosswalk prototype consists of four, free-standing “light poles” that are to be placed in pairs on the sidewalk on either side of an intersection. Each light pole features three high-powered LED lights and a “push-to-cross” button switch. When a pedestrian approaches the intersection and pushes the switch on any of the poles, a radio frequency signal is sent to the other three poles and they all run an identical program in unison. The program cycles the lights through an “on”, “blinking” and “off” phase (similar to existing crosswalk light sequences). The following steps will describe the process for making one of these light poles.
The effect of the Glowing Crosswalk is a temporary field of light that not only illuminates the crossing path but, most importantly, illuminates anyone moving through the crossing path as the light reflects off their body, making the pedestrian more visible to oncoming traffic.
Remove these ads by
Signing UpStep 1: Step 1: Bill of Materials
Here are the components I used to create all four "light poles" used to create the Glowing Crosswalk:
[12x] Light bulb (Ultrafire Cree Xm-l T6 LED 1mode 1000 Lumens 3.7-18v) (from Amazon)
[12x] 18650 3000mah li-ion battery (from Amazon)
[4x] 18650 battery holder (from Digi-Key)
[4x] Umbrella stand (from Pottery Barn)
[4x] Arduino Uno (from Jameco)
[4x] Grove RF- Base Shield (from Epic Tinker)
[4x] Grove - 433MHz Simple RF Link Kit (including a transmitter and a receiver) (from Epic Tinker)
[8x] Grove - Universal 4 Pin 20cm Cable (to connect the transmitter/receiver to the Base Shield) (from Epic Tinker)
[4x] 4” Dia. x 47” Aluminum pipe (ordered cut-to-size from a 20' stock piece at Bayshore Metals)
[4x] 1-1/2” Dia. x 5’ PVC pipe (from any hardware store)
[1x] 1-1/4” Dia. x 2’ PVC pipe (from any hardware store)
[1x] 3” x 2’ ABS DWV Pipe (from any hardware store)
[1x] spool of 20ga galvanized steel strip (from any hardware store)
[1x] 4” Dia. x 12” Acrylic tube (from TAP Plastics)
[4x] 4” Dia. x 1/8” thick acrylic circle (or [1x] 12” x 12”, 1/8” thick acrylic sheet)(from TAP Plastics)
[1x] scrap plywood
[1x] Assorted package of rigid jumper wire (for breadboard)(from Radioshack)
[1x] Assorted spools of 18ga. solid hookup wire (from Radioshack)
[4x] 9V battery
[4x] Breadboard (from Jameco)
[4x] Button momentary switch (from Radioshack)
[4x] Heat sink, TO-220, 1 HOLE (from Jameco)
[4x] TIP 120 NPN Darlington Transistor (from Jameco or Radioshack)
[4x] 2.2K Ohm resistor (from Jameco or Radioshack)
[4x] 10K Ohm resistor (from Jameco or Radioshack)
Tools:
I used a variety of tools, both hand-held and stationary. I try to specify a recommended means of manufacture though most of my build process could be performed using alternative approaches. I relied heavily on the local TechShop for most of the build. It was very helpful to have all the tools I needed in one location along with the space to spread out and work continuously.
Visit Our Store »
Go Pro Today »
My only comment would be to make sure that the lights on the other side of the street aren't in the walker's eyes blinding them while they are walking across a road :P
It's very effective too!
My main concern is that in heavily trafficked roads, the "you must stop" effect of the illuminated pedestrian, is lost by the pedestrian appearing to be illuminated by a car / cars parked in side streets, AND the lack of a red light / yellow flashing light - that is located OVER road and or up very high on the side of the street, so that traffic approaching the crossing, can actually see that there is a pedestrian crossing ahead.
As it stands, to me it's only useful if there is lots of broken glass around and your crossing the street with bare feet.
You need to differentiate between the person being merely illuminated target practice and designating the area as a "pedestrian crossing."
If you need a small town to test on, maybe Tartu, Estonia would be interested.
I truly love the idea!!
Are they synced with the red traffic light ?… They should !…
The only minus I find is this project is that it requires new learnings from the drivers as they should learn to see a crosswalk made of light !…
This is an amazing idea. I love it.
