Introduction: How to Make a Gun - Powerful Match Gun (TUTORIAL)
Learn how to turn trash into a powerful weapon. This shows how to make a serious match gun.This gun can be used for pest control as well as target shooting. i have uploaded a video tutorial of this project. you can just go and check that out & also you should visit my channel. thats the same thing that i used in my hidden gun project.if u haven't watched that video yet then go check that out.
hidden gun (ac)
https://www.youtube.com/watch?v=0kHAJVM5vDU
channel
youtube.com/jinanprojects
THE GUN
https://youtu.be/Q877t33YLa8
music
https://www.youtube.com/watch?v=xshEZzpS4CQ
follow me on
instagram https://www.instagram.com/jinan_projects/
instructables https://www.instructables.com/member/jinan%20projects/
Step 1: Popsicle Part
first cut the Popsicle by half inch. use a knife or something like that to make straight to lines which kinda looks like a rail way. then get ur NICROME wire & use a screw make the coil shape. hold the NICROME wire on rail way like thing as shown in the 7th picture. then just glue it. then take the another half inch Popsicle & place it on the first one and use glue again.
Step 2: Main Part
the steel pipe that is shown in the first picture that is a part of an antena. then i took the Popsicle and used sandpaper to make it thin enough to go inside of the antena. then use glue & then use thread and wrap it around between the Popsicle part and the antena. after that it should look like the 9th picture.
on the 10th picture i used 12v 1amp of an adapter to test it.
Step 3: Gun Powder (NOT REAL)
just use pliers to separate the match head thing to the body. i used a screwdriver's back part to crush the match-head things. i was using the the screwdriver until it looked like fine powder. then i used that part of the match box which ignites the matches. then i mixed two components together.
Step 4: LOAD AMMO
load the ammo as it is shown in the 8th picture
Step 5: TEST!!
actually its pretty damn powerful. just look at the pictures. its even powerful enough to break bottle which is made of glass.
